Tuner Setting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jpmaes0622, this thread has received 5 replies and been viewed 611 times.
post #1 of 6 (permalink) Old 09-16-2009, 11:57 PM Thread Starter
Tuner Setting
I have a 2004 Ford F250 4x2 and was wondering what axle ratio I should put in my tuner? I am guessing it is 3.73, but don't want to mess up the Tranny.
jpmaes0622 is offline
post #2 of 6 (permalink) Old 09-17-2009, 12:15 AM
lilpooh's Avatar
Jack up rear and mark tire with chalk at 12 oclock position, mark driveshaft, now spin tire one full rotation while counting driveshaft mark. If it goes over 4 by a little it's probly 4.10 if it stops before the 4th rotation it's probly 3.73.
Or call dealer and have vin # ran.
2004 F350 CC DRW King Ranch
lilpooh is offline
jpmaes0622 (09-17-2009)
post #3 of 6 (permalink) Old 09-17-2009, 12:45 AM
Dually Club #3
jdydiesel's Avatar
There shold be a tag on the rear end housing that states the gear ratio. It should be attached by one of the cover bolts.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
The Following User Says Thank You to jdydiesel For this addition to TDG:
post #4 of 6 (permalink) Old 09-17-2009, 04:54 AM
SLAPS President
teamroper60's Avatar
Images: 9
Being an F250, it is likely a 3.73 but you can do as has been suggested and know for sure......
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
The Following User Says Thank You to teamroper60 For this addition to TDG:
post #5 of 6 (permalink) Old 09-17-2009, 10:25 AM
mattsn's Avatar
you can also find it on the build sheet/window sticker from when you bought the truck.
mattsn is offline
post #6 of 6 (permalink) Old 09-17-2009, 12:28 PM
6.0brianDRW's Avatar
look at the vehicle certification label insid the door. this will help decode it
https://www.thedieselgarage.com/forum...ead.php?t=1169
2003 jeep wrangler rubicon 4.0/NV3550
'06 f-350 DRW king ranch.(gone but not forgotten)
458rwhp/764rwtq
[email protected]
1989 F-150 300 I6/M5ODR2/6 in a row makes it go
1982 mustang. 351W/414 stroker C4 9" rear. bracket racer
1977 F-100 getting a 1996 12v cummins engine (project)
6.0brianDRW is offline
Help setting up SCT Matt05 2008-2010 6.4L Engine Tuner Forum 9 08-10-2009 01:25 PM
Which setting for MPG? JoeBob1901 1994-2003 7.3L Chips & Tuners Forum 0 02-01-2008 04:12 AM
Tuner Setting? J Hud 5.9L Cummins (2003-2007.5) 3 12-21-2007 11:33 PM
pump setting smc 7.3L and 6.9 IDI (Pre 1994) 4 09-14-2007 04:22 AM
what setting haz-mat19 5.9L Cummins (1998.5-2002) 10 07-20-2005 11:29 AM
