04 ficm on 05 truck?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 3 replies and been viewed 1147 times.
post #1 of 4 (permalink) Old 09-18-2009, 06:45 PM Thread Starter
bootcamp's Avatar
Found 04 ficm for sale cheap and if a person was planning to send it in to be reprogrammed by one of the vendors on here. Would it work on a 05 or does the ficm need to be from a 05 even to be reprogramm?
Thanks Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 4 (permalink) Old 09-18-2009, 08:08 PM
strokin6L's Avatar
an '04 tuned ficm will work on your '05. I just put an '03 tuned FICM from ID on my buddy's '05. It don't matter what year truck the FICM came off of cause it's only gonna get recalibrated.
strokin6L is offline
The Following User Says Thank You to strokin6L For this addition to TDG:
bootcamp (09-19-2009)
post #3 of 4 (permalink) Old 09-18-2009, 09:17 PM
SLAPS President
teamroper60's Avatar
Images: 9
x2
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
The Following User Says Thank You to teamroper60 For this addition to TDG:
post #4 of 4 (permalink) Old 09-19-2009, 08:31 PM Thread Starter
bootcamp's Avatar
I had found one on ebay but the seller has back out of selling it. Thant s#$ks. I guess I will keep looking!
USMC 87-90 MOTOR-T
bootcamp is offline
03 6.0 ficm despain85 Ford Parts 2 08-24-2009 11:58 PM
ficm albert bryans Whats Been Sold 1 03-14-2009 07:30 PM
Ficm id stacks 2003-2007 6.0L Power Stroke 9 01-27-2009 10:48 AM
Ficm stacks 2003-2007 6.0L Power Stroke 14 01-19-2009 04:05 AM
Pcm, Tcm, Ficm MOMBENZ 2003-2007 6.0L Power Stroke 0 09-21-2006 01:20 PM
