new to the fourm - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokin it up, this thread has received 12 replies and been viewed 1120 times.
post #1 of 13 (permalink) Old 09-19-2009, 11:00 PM Thread Starter
strokin it up's Avatar
new to the fourm
yeah i was just wondering if you guys could give me some advice. So i have an 03' regular cab 6.0 with a 6 speed which i currently have a hypertec on. Well i was thinking of selling the hypertech and getting a sct livewire. My question is are sct's preloaded tunes any good? I dont really need any custom tuning and, will i experience any problems? The truck has 62,000 miles on it and never been in for waranty work once. would appreciate any advice thanx
strokin it up is offline
post #2 of 13 (permalink) Old 09-20-2009, 12:14 AM
lilpooh's Avatar
I use to run the hypertec adjustable on the fly a long time ago, the canned tunes on the sct are way better on power than hypertec. As far as running into any problems, there are no guarantee that you won't have mechanical issues with your truck even in stock form
Edit to TDG!!
It's recommended that an exhaust and gauges be put on also,which the I believe the the livewire has.Take some time and use the search on this site to read up on the 6.0!
also the hypertec don't control the tranny and can possibly mess it up.
2004 F350 CC DRW King Ranch
lilpooh is offline
strokin it up (09-20-2009)
post #3 of 13 (permalink) Old 09-20-2009, 04:05 AM Thread Starter
i like the power of the hypertech it just makes my engine really choppy on the extreme setting when letting out on the clutch and i also want to monitor more things than my pillar guages show. will and sct work with a manual tranny?
03 F-350 srw 6.0l 6speed Reg. cab straight pipe 5'' aero turbine tip, hypertech inline tuning module, autometer nv series pillar guages boost pyro. and trans temperature. Recon line of fire and l.e.d cab lights. Rough country leveling kit
post #4 of 13 (permalink) Old 09-20-2009, 04:14 AM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
yes it will work with a manual tranny. I you would please fill out your sig so people can see some of the things done to your truck and help you out a little better. As far as monitoring go's you said you have gauges what do you have? The live wire can monitor some.
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #5 of 13 (permalink) Old 09-20-2009, 04:39 AM Thread Starter
i have guages for my boost egts and trans temp. I know that the trans temp really isnt necessary but i already had the gauges which i had intended to put in my old obs powerstroke but i sold it and the gauges were paid for so i put them in. Im mostly just of my truck being so choppy everytime i let out on the clutch and a little more power never hurt anyone do you think the livewire would be a good switch?
post #6 of 13 (permalink) Old 09-20-2009, 12:28 PM
lilpooh's Avatar
How many miles on clutch?
lilpooh is offline
post #7 of 13 (permalink) Old 09-20-2009, 12:31 PM
International350's Avatar
Honestly the SCT is the greatest tuner for the money, they know what they are doing with powerstroke tuning and are very helpful if you need something. as far as livewire i dont have that i just have programmer, basically same thing, just dont have the gauge monitors.
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
The Following User Says Thank You to International350 For this addition to TDG:
post #8 of 13 (permalink) Old 09-20-2009, 02:51 PM Thread Starter
it has the original clutch yet and it's never slipped yet and one more thing how much boost should i be seeing? Sometimes at WOT I can get my boost guage to go past 35 is that bad?
post #9 of 13 (permalink) Old 09-20-2009, 05:37 PM
lilpooh's Avatar
I don't think a sct will help with the choppy clutch, it might make it worse with the added power.as far a the boost 25-35 in the norm, depends a what you have done and what flash you have in your truck.
Hopefully another member will chim in about your choppy clutch issue, might be glazed over.
lilpooh is offline
post #10 of 13 (permalink) Old 09-21-2009, 01:59 AM Thread Starter
Idk if its an issue with the clutch or just the way the tuner makes the truck run. When i let out it will shoot out puffs of black smoke which is always cool but it makes the motor like lope. And its hard to get a real staright answer becuase there isnt many 6.0s with 6speeds but i appreciate all the help i can get
hello new to the form and my first diesel fourm 03durlover Introductions 17 08-14-2009 04:06 AM
New in the fourm. Spuppy Introductions 5 06-11-2007 12:09 PM
new to the fourm and ISSPRO gmdangelo Introductions 11 05-13-2007 09:57 PM
how about another hobbies fourm House Site Information 2 04-05-2006 12:26 PM
