boost with costom tune - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chris Hogeland, this thread has received 11 replies and been viewed 1032 times.
post #1 of 12 (permalink) Old 09-24-2009, 12:45 AM Thread Starter
Hey guys what is your boost at with A costom tune? Mine is around 20/21#. Should it be higher?
Thanks
Chris Hogeland
TWISTED 6 RACING
Chris Hogeland is offline
post #2 of 12 (permalink) Old 09-24-2009, 02:59 AM
SLAPS President
teamroper60's Avatar
Images: 9
Roughly 30psi is what I see with all my tunes.. I think yours sounds a little low.. I'd be looking for a leak someplace though before I blamed the tune.. When I had a split in the IC boot from the turbo to the hot side tube, 20psi was all I could get....
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #3 of 12 (permalink) Old 09-24-2009, 09:26 PM
Slow 6.0
most i see at wot is 30psi least i see is 20psi. really depends on the rpms, what gear the tranny is in, load and converter being locked or unlockd.
2006 F350 XLT 4x4
SICKS-O is offline
post #4 of 12 (permalink) Old 09-24-2009, 09:29 PM
International350's Avatar
Def check this boot, its on inner side thats hard to see that it cracks. My full throttle is 26psi, and throttle built boost is 33psi
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #5 of 12 (permalink) Old 09-24-2009, 11:36 PM
SSpeeDEMONSS's Avatar
32-34psi.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #6 of 12 (permalink) Old 09-25-2009, 12:31 AM
Originally Posted by SSpeeDEMONSS View Post
32-34psi.
you get these pressures at WOT, if so not to sound dumb but how, mine only gets this if on highway and it doesnt drop gear but builds 33 psi an takes off with what feels like boost only. if that makes any since
post #7 of 12 (permalink) Old 09-25-2009, 05:24 AM
adambomb's Avatar
^ yeah that is usually when the torque converter is locked and the engine is lugging a little bit but not downshifting because it's got the power and boost in the tune. pretty common. to the OP your boost sounds low like pretty much everyone already said.
2005 6.0L F350 Lariat CCLB FX4
*Industrial Injection Hybrid Turbo*90hp DDP Injectors*SCTX3 Custom Innovative/Spartan*ARP Studs/Stocks Head Gaskets*Banks Techni-Cooler*FASS*AFE Intake*4" MBRP Exhaust*AutoMeter PhantomII Boost/Pyro/Trans Gauges*2.5" ICON Suspension*35" Xtreme AT's*18"KMC Monsters*Power Slotted Rotters w/ Ceramic Brake Pads*Pioneer AVIC N3-Nav,Rear View Cam,iPod,Voice Activation*
adambomb is offline
post #8 of 12 (permalink) Old 09-25-2009, 09:11 PM
lilpooh's Avatar
when cruising at hy-way speed, if you want the tranny to down shift, let off the gas pedal and tap the break pedal, then back on throttle and it should down shift for you.
2004 F350 CC DRW King Ranch
lilpooh is offline
International350 (09-26-2009)
post #9 of 12 (permalink) Old 09-25-2009, 10:35 PM
i could get 30-32 WOT in any gear. from a dig it would get 30+ for sure. with the TC locked on the freeway it would do 32-34. i have a video of it somewhere. let me go find it.
post #10 of 12 (permalink) Old 09-25-2009, 10:39 PM
here's just rolling into it.
65mph rolled into it, let off, then rolled back into it to WOT up to 100mph.
note, both videos are of the truck running crappy. first video with several problems, FICM, injectors, etc... second video had a really weak HFCM.
ID aggressive tune, boost level scameron 2003-2007 6.0 Tuner Forum 15 05-29-2009 08:31 PM
ID std. street tune boost level scameron 2003-2007 6.0 Tuner Forum 1 05-03-2009 07:34 PM
Extreme tune or economy tune Horn399 2003-2007 6.0 Tuner Forum 14 03-15-2008 03:17 PM
ELITE insanity tune vs IDP extreme tune flaresniper 2003-2007 6.0 Tuner Forum 21 11-12-2006 05:56 PM
Superchips Perf. Tune feels slower than Econ tune.. crappace 2003-2007 6.0 Tuner Forum 4 05-10-2006 09:59 PM
