Extreme Street - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BrianHonda629, this thread has received 4 replies and been viewed 1117 times.
post #1 of 5 (permalink) Old 09-24-2009, 06:05 PM Thread Starter
honda629
Extreme Street
Has anyone adjusted the shift points or anything or the Extreme street tune from Innovative if so what???
If i got a smoke tune from innovative is that going to clog the turbo veins like a smoke switch would??
BrianHonda629 is offline
post #2 of 5 (permalink) Old 09-24-2009, 07:19 PM
SmokeCloud's Avatar
What's the purpose for a smoke tune? there really is none to be honest, all your doing is burning unnecessary fuel. and showing off to that affect.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #3 of 5 (permalink) Old 09-24-2009, 08:52 PM
lilpooh's Avatar
I have adjusted mine up to 5%. Ran it for about a month, it does make it shift more firmer.then took it out, with my tranny mods it made it too crisp.
Imo, the smoke tune would just be a waste of fuel and also make the turbo viens stick if use to much.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #4 of 5 (permalink) Old 09-24-2009, 08:53 PM
International350's Avatar
If you get those tunes from Innovative, there shouldnt be any shift points, Eric programs all that into the tune itself, the only thing left to adjust is wheel size, gear size, and shift pressure. If your tire size is off then the shifting will shift to early or late.
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #5 of 5 (permalink) Old 09-24-2009, 09:24 PM
Slow 6.0
never had a need to adjust anything with the shifting, everything is spot on imo. smoke tunes stupid imo..
2006 F350 XLT 4x4
SICKS-O is offline
Extreme Street Tunes Rinkopr 2003-2007 6.0 Tuner Forum 47 04-16-2009 08:23 PM
extreme street kkibbey 2003-2007 6.0 Tuner Forum 7 11-23-2006 12:45 PM
Innovative SCT Extreme Street John Boy 2003-2007 6.0 Tuner Forum 4 07-18-2006 02:34 AM
Only 19lbs on extreme street. Leak maybe? EJ Krueger General Ford Truck and Excursion 6 05-24-2006 07:30 PM
SCT and Extreme Street John Boy 2003-2007 6.0 Tuner Forum 7 05-19-2006 09:01 PM
