Zodad? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Conair, this thread has received 8 replies and been viewed 1272 times.
post #1 of 9 (permalink) Old 09-29-2009, 04:58 AM Thread Starter
Zodad?
I see a lot of people here talking about Zodad. What is a zodad?
Conair is offline
post #2 of 9 (permalink) Old 09-29-2009, 05:02 AM
lilpooh's Avatar
between the air box and grill, you cut out the plastic to make a hole to allow the air cleaner to get cooler air. you will find several write ups on this in the ford modification thread.
just so you know this forum area is for tunes, such as SCT,edge,bulley dog,ect,ect. its for the electronic performance.
you will get better responses if you post up in the right areas.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 9 (permalink) Old 09-29-2009, 05:13 AM Thread Starter
Thanks. I'm new to using a forum. I just joined the other day.
Conair is offline
post #4 of 9 (permalink) Old 09-29-2009, 05:23 AM
lilpooh's Avatar
welcome to the garage,I still post in the wrong areas Thier are alot of great people on here. and they will just about bend over backwards to help you out.I've learned alot about these trucks and I know I have a whole lot more to learn.
lilpooh is offline
post #5 of 9 (permalink) Old 09-29-2009, 05:44 AM
bushpilot's Avatar
couple of photos at this link ->
http://s231.photobucket.com/albums/e...350-AIRFILTER/
Don R.
Truck Audio,
bushpilot is offline
post #6 of 9 (permalink) Old 09-29-2009, 02:45 PM
As lilpooh said, it is a hole between grille and airbox.
1. Open Hood
2. Remove Grille (There are 4 Phillips Head Screws on Top and 4 Tabs that need to be lifted on the bottom). The Grille then come right off.
3. The upper right hand corner (Driver's Side) below the radiator support beam is a plastic piece that is at an approx. 30-45 degree angle.
4. Using a dremel tool, cut out an area (size you feel appropriate) in front of the air box so that the air is flowing directly into the airbox.
jpmaes0622 is offline
post #7 of 9 (permalink) Old 09-29-2009, 03:31 PM
bushpilot's Avatar
its NOT plastic, its fiberglass <wear gloves & stay away from the dust>
Don R.
Truck Audio,
post #8 of 9 (permalink) Old 09-29-2009, 03:41 PM
Yes, Sorry, it is Fiberglass, but the flimsy little dremel disc cuts through it like it Buttah Baby!
post #9 of 9 (permalink) Old 09-29-2009, 05:29 PM
bushpilot's Avatar
they do, but a hole saw on a drill will get the job done even faster...
iirc i used a 2" hole saw...cutting TWO holes, one on top of the other
in a "figure 8" scenario...then i just trimmed the portion in between the
two holes...makes for a nice finished oval.
Don R.
Truck Audio,
