Intake Elbows - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by awhotrods, this thread has received 11 replies and been viewed 1427 times.
post #1 of 12 (permalink) Old 09-30-2009, 04:52 AM Thread Starter
awhotrods's Avatar
Intake Elbows
I have an 03 SD with the "throttle body" built into the elbow. I have been told 05 up elbows are interchangeable with mine. So does this mean I can order an aftermarket elbow for an 05 & bolt it on? I'm looking at the accufab version. Going to have intercooler pipes & elbow hi-temp coated satin black once its apart. Anyone know which vendor has the best price on the accufab elbow?
03 F350 4x4 6.0 PSD
SCT X3 with Eric's Xtreme Street Tune
RCD EGR DELETE
RCD 155's
4" TURBO BACK STRAIGHT PIPED
DIESEL SITE COOLANT FILTER
ACCUFAB 05 ELBOW
STATOR REMOVED (NO ISSUES)
ZOODAD MOD
ISSPRO TRIPLE GAUGES
05 HARLEY FRONT END
08 REAR CONVERSION
awhotrods is offline
post #2 of 12 (permalink) Old 09-30-2009, 05:25 AM
lilpooh's Avatar
You can just get a stock '05 elbow,and it will bolt right up.and just cable tie the wires.before you install you can paint or polish it and even tap it for ports. Your not gaining much HP,the '05 elbow will get rid of the throttle plate,if you even have one.
when I did mine thier was no throttle plate.I have the early '04 motor aka '03 motor.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 12 (permalink) Old 09-30-2009, 05:47 AM
SLAPS President
teamroper60's Avatar
Images: 9
I put an 05 elbow on mine. I polished mine but you could paint it, powdercoat it or whatever you want. The elbow I put on was given to me so I don't know what one costs from Ford but I doubt it is nearly as much as those being sold by the aftermarket and for what little gain is to be had from this mod, I can't see spending the big bucks for one.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #4 of 12 (permalink) Old 09-30-2009, 03:11 PM
Yes it will bolt right up, but you won't see any performance gains. I put the full Banks Technicooler setup on mine and didn't really notice any difference.
cartmanea is offline
post #5 of 12 (permalink) Old 10-02-2009, 02:07 AM
I Wanna Go Fast!
brentos's Avatar
they are not worth the money just find ya a 05 one
brentos is offline
post #6 of 12 (permalink) Old 10-02-2009, 02:14 AM
Or just leave it alone. Keep in mind, you're screwing into aluminum. When I installed my Banks kit, two of the four bolts stripped out before the torque spec and I ended up heli-coiling all four, not a fun Sunday before driving back to school.
post #7 of 12 (permalink) Old 10-02-2009, 02:23 AM
I Wanna Go Fast!
brentos's Avatar
that would suck neither of my studs stripped when installing my banks. guess i got lucky.
brentos is offline
post #8 of 12 (permalink) Old 10-02-2009, 02:51 AM
If I remember, spec was 9 ft-lbs and they stripped around 6-7. It had never been apart, but the threads felt sloppy loose before I even started tightening. A machinist friend told me he uses helicoils in aluminum every time, even the first time assembling, because it just strips out so often and you shouldn't tighten into it more than once.
post #9 of 12 (permalink) Old 10-03-2009, 01:48 AM
NGHTRGR's Avatar
PM sent
Black 05 Excursion -MBRP T-Back minus kitty, Airaid w/Zoodad, FS2500, Coolant Bypass, ATS Headstuds, ITP Reg Rtn, Full EGR Delete, DFUSER Light Harness, Keystone Heat Extractor Hood 2 Tone, CCV Reroute, 4-6" lift, 35" MT Baja MTZ's on Classic Locks, SCT X2 w/Innovative Extreme Race
NGHTRGR is offline
post #10 of 12 (permalink) Old 10-10-2009, 05:55 AM
When replacing the Intercooler with upgraded piping and intake elbow on an 03-04, can you or should you replace it with the 05+ model kit?
jpmaes0622 is offline
Performance Elbows 06 SuperDuty 2003-2007 6.0L Power Stroke 9 07-13-2009 04:48 PM
5 inch exhaust elbows StrokerDude Supporting Vendors Forum 2 03-28-2009 02:39 PM
Intake elbows? rademac 2003-2007 6.0L Power Stroke 13 11-08-2007 04:33 PM
Power Elbows Again... '05 elbow in an '04? bakantor 2003-2007 6.0L Power Stroke 7 03-09-2007 03:54 PM
ABout those Elbows. lee boy 2003-2007 6.0L Power Stroke 5 02-20-2007 09:47 PM
