Fuel pump?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummins-ECL, this thread has received 4 replies and been viewed 782 times.
post #1 of 5 (permalink) Old 10-03-2009, 07:45 PM Thread Starter
Cummins-ECL's Avatar
Send a message via AIM to Cummins-ECL
Fuel pump??
which fuel line do i put an added fuel pump on ?? i see three lines under the driver door???
2005 GMC 2500HD DURAMAX
-ATS TRANNY "BUILT BY UPTEMAX DIESEL
-EFI CUSTOM TUNING BY UPTEMAX
-AFE COLD AIR INTAKE
-4in. TURBO BACK TO 6in angle cut stack
-CLEAR CAB LIGHTS
-CHROME DOOR HANDLES
-BILLET GRILL
-HUMMER WHEELS RUNNIN 315/75/17 DYNAPRO'S
1997 DODGE 2500 CUMMINS 12V
-NO FUEL PLATE
-ADJUSTED AFC & STAR WHEEL
-T/C LOCK-UP SWICTH
"IF IT AINT SMOKIN IT MUST BE BROKEN"
"UPTEMAX DIESEL"
Cummins-ECL is offline
post #2 of 5 (permalink) Old 10-03-2009, 07:46 PM Thread Starter
**** its an 2003 6.0
-CLEAR CAB LIGHTS
-BILLET GRILL
-NO FUEL PLATE
-T/C LOCK-UP SWICTH
"UPTEMAX DIESEL"
post #3 of 5 (permalink) Old 10-04-2009, 01:44 AM
I Wanna Go Fast!
brentos's Avatar
there is one suction line (behind the pump) that is the one you want the pusher on. then there is the motor supply line comming out of the pump then there is the return line from the motor.
brentos is offline
post #4 of 5 (permalink) Old 10-04-2009, 04:58 PM Thread Starter
what is the best way to identify that line??
-CLEAR CAB LIGHTS
-BILLET GRILL
-NO FUEL PLATE
-T/C LOCK-UP SWICTH
"UPTEMAX DIESEL"
post #5 of 5 (permalink) Old 10-04-2009, 09:18 PM
SLAPS President
teamroper60's Avatar
Images: 9
If you lay down under your truck and look up at the HFCM, the tank to pump feed line is the one on the lower left corner of the manifold attached to the HFCM.. The lower right line is the pump to engine line.
The upper right is the engine to pump return line and the upper left is the pump to tank return line..
On a related note, I took an HFCM apart the other day and looked it over.. I found a flapper style check valve in it that to me looks like a pretty bad restriction. Where it is, the pump would basically have to suck it open. I wondering if the pump is having to work harder than it needs to because of that valve. I am also wondering what would happen if that was removed and a higher flowing, ball type check valve were placed in the feed line instead...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
new fuel pump camojeeper 1994-2003 7.3L Power Stroke 1 04-15-2009 12:57 PM
CP3 Fuel Pump and the 6.4L ?? onebadf150 2008-2010 6.4L Power Stroke 1 10-08-2007 09:35 PM
fuel pump cfbrown 5.9L Cummins 12 Valve (1994-1998.5) 1 04-22-2007 07:33 PM
ACCEL 110GPH Fuel Pump/Lift Pump maxxis_mudder Whats Been Sold 0 12-10-2006 03:24 PM
BOOST-A-PUMP burnsout fuel pump!!!!! koolkat812 2003-2007 6.0L Power Stroke 26 09-02-2005 01:21 AM
