FICM question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Snake, this thread has received 11 replies and been viewed 7353 times.
post #1 of 12 (permalink) Old 10-06-2009, 12:48 AM Thread Starter
Sumo Blue
FICM question
Not sure if this is the right place to post this, but I had to start somewhere.
I'm pretty sure my FICM is going bad and I've found a couple of folks with FICM's for sale.
My question is, can I use any FICM in my 2005? I've been reading that the 03's were a little different than the 04-07's and I don't want to buy something that isn't going to work. Yes, I know the FICM will need to be programmed.
The one person I found selling a brand new one was able to give me an International part # (1845117C5-5847068) but I haven't had any luck cross-referencing that to a Ford part # to see if this one is compatible. Before I get flamed, yes I looked in the 190 page International cross-reference guide and yes used the search button.
Any help ya'll can provide would be greatly appreciated.
Thanks in advance.....
--Snake
__________________________________________________ ________________________________________
2005 Harley Davidson F-250 Superduty #3991, true blue
"Slightly" Modded
Snake is offline
post #2 of 12 (permalink) Old 10-06-2009, 01:37 AM
SLAPS President
teamroper60's Avatar
Images: 9
It is my understanding the FICM is the same for all years. You should be able to buy any of them, have it programmed and use it on your truck... The difference in the 03 FICM was software related, not hardware...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #3 of 12 (permalink) Old 10-07-2009, 10:38 PM
NuttyProfessor's Avatar
The hardware was transparent to the years, software was year specific. There was a recent hardware change to the FICMs to make them more robust and less prone to failure.
Nutty
NuttyProfessor is offline
post #4 of 12 (permalink) Old 10-07-2009, 11:14 PM
SLAPS President
Images: 9
Nutty
I read where you said that in another forum. That was news for me. But the FICMs are still able to be swapped from year to year, correct??
#43
post #5 of 12 (permalink) Old 10-07-2009, 11:16 PM
Yes, that is correct.
The Following User Says Thank You to NuttyProfessor For this addition to TDG:
teamroper60 (10-07-2009)
post #6 of 12 (permalink) Old 10-08-2009, 08:59 PM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
The hardware is the same for ford and ih. If you tell the ih dealer it is for a ford most will tell you it does not work. I went thru this a few months ago on my truck. About the cheapest thing I could find new was $600+ depending on the ford or ih dealer. Some were $1000 or more. The dealer ended up selling me the one I got for $550. He knew I was shopping and gave me a break
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #7 of 12 (permalink) Old 10-08-2009, 09:49 PM
SLAPS President
Images: 9
Nutty
BTW, do you know the part number for the updated FICM??
#43
post #8 of 12 (permalink) Old 10-09-2009, 12:19 AM
Same part number except the C6 at the end.
Nutty
post #9 of 12 (permalink) Old 01-28-2010, 07:20 PM
Ford FICM replacement
Hello, my 2005 F350SD with 6.0L just stalled on the driveway and would not restart - thought it was bad fuel/water/the usual, but new filters later and two nights in 10F weather - no luck. Snap On SOLUS confirmed that FICM had died, but still responded. Truck had high pressure oil pump fail 2 years ago and do similar no start condition with exception that FICM failure allowed one crack and Hipres had no pops whatsoever. Year later, oil cooler failed - pressurized glycol circuit with oil, now residue ruining all hoses as dealer did not flush properly-pudding in tank. As if this was not enough, constant 11MPG since new and now FICM dies out of warranty. Sorry, needed to vent -
To the point FICM 184511C5 at local salvage for $255 (great!), but not "new" improved C6 suffix - from my dealer mechanic buddy (with solus) $600 cash his cost. Navistar NEW part sub is 1847094C95 (their old sub 1847094C94) if anyone can benefit offered to me for $695 in MIdwest area...
Does anyone know if PHP can send already programmed FICM with modified software more akin to 2003 version (better mileage needed desperately), or do you send module and get it flashed and then sent back?
Slayth is offline
post #10 of 12 (permalink) Old 01-29-2010, 01:52 AM
My FICM died about 6 months ago. 2003 with 112,000 miles. Searched all salvage yards in the houston area (alot of them) and found 1. It was from the same year. Bought it for $250.00 plugged it in same day and truck runs fine. No programming needed. Truck starts instantly and seems to have improved power also. Guess i got lucky. 5000 miles and running fine.
03lariatsd is offline
03 6.0 ficm despain85 Ford Parts 2 08-24-2009 11:58 PM
FICM Harness question 05fx4 2003-2007 6.0L Power Stroke 5 08-11-2009 11:49 PM
ficm Lubbockguy1979 2003-2007 6.0L Power Stroke 2 05-13-2009 02:01 AM
Need ficm BogginF350 Supporting Vendors Forum 0 03-20-2009 02:37 AM
ficm albert bryans Whats Been Sold 1 03-14-2009 07:30 PM
