sct help!!???!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sjladd6_0L, this thread has received 4 replies and been viewed 564 times.
post #1 of 5 (permalink) Old 11-01-2009, 12:50 PM Thread Starter
sct help!!???!!!
ok just went out to the truck and started it up. Plugged in the sct and it never turned on! checked both of the conections and they are fine, it worked yesterday!? It was left out in the cab last night but it only got down to 45 degrees.
Just got the truck back and had arp head bolt studs and egr delete kit done.. Truck was programmed to stock went it was dropped off at the shop. But that was last week and like i said it worked fine yesterday!?!!?!
any ideas?????
sjladd6_0L is offline
post #2 of 5 (permalink) Old 11-01-2009, 12:55 PM Thread Starter
further more i just plugged it into my lap top and it works fine, but dont wont to down load or upgrade anything because my truck is still on the extreme mode....
Where do i look from here???
post #3 of 5 (permalink) Old 11-01-2009, 06:05 PM
you probably have a blown fuse. check to see if your cig lighter works.
04 f250 ext. cab short bed
11-03 engine
4" magnaflow straight pipe
03' turbo
access roll up cover
putco bed rails
spartan tuning
ficm tune by I.D.
2004 Psd is offline
The Following User Says Thank You to 2004 Psd For this addition to TDG:
sjladd6_0L (11-02-2009)
post #4 of 5 (permalink) Old 11-01-2009, 07:52 PM
lilpooh's Avatar
Give SCT a call, they should be able to help you, might have corrupted firm ware, also when working right again save a copy of your stock file to your pc.
It's also a good idea to save all your files to a flash drive or some other device just in case your pc goes down.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #5 of 5 (permalink) Old 11-02-2009, 09:52 PM Thread Starter
checked all the bus fuses under the dash they are all fine. E-mailed sct and they said that my obd port needs to be checked for voltage. So checked everything out and the alternator is goin bad!!!
