Innovative Agressive Street Boost - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kwissman, this thread has received 8 replies and been viewed 1439 times.
post #1 of 9 (permalink) Old 11-18-2009, 12:34 AM Thread Starter
I installed the ID Agressive Street tune last night and drove the truck today to work and to pick up the kids. I have 35" tires and set my tire revs when I installed the tune.
When I go WOT my boost only went to 20PSI. I was able to get to 26-27 psi in the same situation with the stock tune the day before installing the new tune. I did notice quite a bit of haze at WOT with the 20PSI. I still have the fully functioning EGR.
Is the boost low on purpose to keep from overboosting?
This tune does add a lot of power and chirped the tires going from first to second on a partial throttle take off from a light. I the shifting is firm and will hopefully settle down a little bit after the transmission learns the new tune in a few days.
Thanks
2005 F250 6.0 CCSB
SCT X3 ID Agressive Street
kwissman is offline
post #2 of 9 (permalink) Old 11-18-2009, 01:40 AM
I can't tell you whether you should be getting 26-27 boost on the agressive Street. Although I don't see why not. Last week I put in the Street Firm which is less agressive and I have 26 lbs boost. As for the shifting, it will calm down after 100 miles. I haven't tried the Extreme Street yet, but I love the Street Firm. You should ask Eric about this, he should certainly be able to help you. I'm sure there are few people will chime in also and let you know.
2007 Ford F350 FX4 Crew Cab long Bed, SCT X3, Innovative Tunes by Eric with Edge Insight and EGT. Magnaflow 4" Turbo back. EGR Cooler blocked off. RCD 2.5 Leveling lift kit, 35/12.5/18" Toyo MT. ARP Studs
Gdief is offline
post #3 of 9 (permalink) Old 11-18-2009, 02:59 AM
lilpooh's Avatar
IMO, put the stock tune back in and see if you still only get 20psi, maybe by dumb luck you have a torn IC boot,or stuck vanes. If the stock tune is getting 26-27psi then call ID.
lilpooh is offline
post #4 of 9 (permalink) Old 11-19-2009, 12:19 AM
UpstateDieselGuy's Avatar
Also, it isn't uncommon to have lower boost readings and more power. Often Tuners are able to make more power with less boost. It can also be affected by converter locking, etc. Chris
SOLD
UpstateDieselGuy is offline
post #5 of 9 (permalink) Old 11-19-2009, 01:24 AM
I run the same tune and see about 22 psi at wot...I think this tune is just a little safer and makes alot of power without a ton of boost which I personally like. It will spike to 25 to 26 psi at the shift points. I think it is normal what you are experiencing
smknf250 is offline
post #6 of 9 (permalink) Old 11-19-2009, 02:11 AM Thread Starter
I emailed Innovative and they replied that the approx 20PSI boost is normal and that they could add more, but it would wear out the turbo faster. Nothing to worry about.
Thanks for the responses.
kwissman is offline
post #7 of 9 (permalink) Old 11-26-2009, 02:44 PM
Sader's Avatar
It takes a bit for the shifting to get settled in, so give that time. You will love it! As for the peak boost, mine didn't see peak boost unloaded.
Put some weight in it or behind it and you will know for sure.
Cheers
2016 F350 C/C, S/B, FX4, PSD, T/S, Loaded Lariat, best PSD yet !
2005 F250 C/C, S/B, FX4, PSD, T/S, Loaded Lariat, Love my 6.0...............movin' on up
2004 F250 S/C, L/B, 4x4, PSD, T/S, XLT - Great Truck traded on the 05
2000 Excursion Limited, PSD, 4x4, Stock, sadly it's gone...
1991 F250 Reg. Cab L/B, 4x4, 7.3L diesel, E4OD, Lariat ran the wheels off
" We may or may not worship God, but John Moses Browning made sure we can choose "
"Security without Liberty is called prison"
― Benjamin Franklin ―
Sader is offline
post #8 of 9 (permalink) Old 11-27-2009, 03:33 AM
********* and Mafia #90
Bcarriveau's Avatar
Did you set the Tire/Revs or Measure it your self and let eric know before he wrote the tune? If its off the shifting wont be right. it makes a knight and day difference.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #9 of 9 (permalink) Old 11-29-2009, 01:19 PM Thread Starter
I did measure and set the tire revs when I loaded the tune. The shifting has settled in and my mileage appears to have gone up some also.
kwissman is offline
Tags
agressive street, boost, psi
Just installed Innovative Street Firm, have a question Gdief 2003-2007 6.0 Tuner Forum 13 11-26-2009 02:55 PM
Innovative Tunes - Street or Xtreme Street? cartmanea 2003-2007 6.0 Tuner Forum 57 05-11-2009 02:13 AM
innovative agress. street utlonghorns416 2003-2007 6.0 Tuner Forum 20 02-17-2009 03:15 PM
Innovative SCT Extreme Street John Boy 2003-2007 6.0 Tuner Forum 4 07-18-2006 02:34 AM
Innovative Street Tune?? jschall 2003-2007 6.0L Power Stroke 10 09-11-2005 02:55 AM
