Best bang for the buck intake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by awhotrods, this thread has received 20 replies and been viewed 3071 times.
post #1 of 21 (permalink) Old 11-18-2009, 06:51 AM Thread Starter
awhotrods's Avatar
Looking for a good air intake for my 03 PSD. So many to choose from, some of the prices are ridiculous as well!! Looking for the best bang for the buck, any suggestions?
03 F350 4x4 6.0 PSD
SCT X3 with Eric's Xtreme Street Tune
RCD EGR DELETE
RCD 155's
4" TURBO BACK STRAIGHT PIPED
DIESEL SITE COOLANT FILTER
ACCUFAB 05 ELBOW
STATOR REMOVED (NO ISSUES)
ZOODAD MOD
ISSPRO TRIPLE GAUGES
05 HARLEY FRONT END
08 REAR CONVERSION
awhotrods is offline
post #2 of 21 (permalink) Old 11-18-2009, 11:42 AM
lilpooh's Avatar
Stock air cleaner is good to handle up to 500hp, and if you ment elbow, A '05 elbow will bolt to '03-'04, and eliminate the egr throttle body, also thier are no real performance gains with aftermarket set-ups for either one.
lilpooh is offline
post #3 of 21 (permalink) Old 11-18-2009, 02:52 PM
StrokerDude's Avatar
Seen Dyno sheets from a Dyno I trust of the AFE intake elbow gaining 20HP. This was a run it, switch it, run it scenario to see what it would gain...
Alex C.
StrokerDude is offline
post #4 of 21 (permalink) Old 11-18-2009, 03:14 PM
lilpooh's Avatar
Was this on a bone stock motor,or was thier other mods that may have helped (Bigger turbo,IC,ect)?
2004 F350 CC DRW King Ranch
lilpooh is offline
post #5 of 21 (permalink) Old 11-18-2009, 04:00 PM
adambomb's Avatar
best bang for the buck STOCK & Zoo Dad if you wanna get a little more flow.
i run the AFE stage I which slides in the same place as the stock.
2005 6.0L F350 Lariat CCLB FX4
*Industrial Injection Hybrid Turbo*90hp DDP Injectors*SCTX3 Custom Innovative/Spartan*ARP Studs/Stocks Head Gaskets*Banks Techni-Cooler*FASS*AFE Intake*4" MBRP Exhaust*AutoMeter PhantomII Boost/Pyro/Trans Gauges*2.5" ICON Suspension*35" Xtreme AT's*18"KMC Monsters*Power Slotted Rotters w/ Ceramic Brake Pads*Pioneer AVIC N3-Nav,Rear View Cam,iPod,Voice Activation*
adambomb is offline
post #6 of 21 (permalink) Old 11-18-2009, 08:06 PM
FFRyan's Avatar
Stockkkkkkkkkkkkkkkkkkkkkk
FFRyan is offline
post #7 of 21 (permalink) Old 11-18-2009, 11:31 PM
jeffro22's Avatar
afe stage 1 can generally be found used for cheap and fit in stock location. this way you get a reusable filter. Been running one for about 40K miles with no issues at all
2005 F-250 w/ SCT Looney Tune
MRBP 4" TB Exhaust No Cat
AFE Intake
ARP studs / Black HG's
RCD EGR Delete
Amsoil Oil Bypass, Homemade Coolant filter
Trusted Perf. Reg Return Stage 2
jeffro22 is offline
post #8 of 21 (permalink) Old 11-19-2009, 02:54 PM
It was nothing more than the regular.... Intake, Exhaust, Tuner. I think it was ran with and without elbow both before and after the elbow.
Alex C.
The Following User Says Thank You to StrokerDude For this addition to TDG:
lilpooh (11-19-2009)
post #9 of 21 (permalink) Old 11-20-2009, 01:52 AM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
zoodad and do some looking at the stock intake take out the bends, the flex sections etc make it better keep the stock filter and save $300 bucks that would be the best bang for the buck
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #10 of 21 (permalink) Old 11-20-2009, 02:36 AM
Diesel Duo's Avatar
If bang for your buck is what you are after. You must also take into consideration the cost of replacement filters.
Think about a cleanable drop in.
my $0.02
DD
No brand loyalty, just a love of diesels!!
1994 Ram 2500 CTD K&N intake, MBRP exhaust, full Goerend tranny, #100 Fuel plate, 60# valve springs, 4k GSK, Thuren steering stabilizer, Thuren Track Bar, +2.5" progressive rate coil springs, Bilstein 5100's, BD Diesel SBS, chassis mods, 315/75R16 Goodyear Wrangler Duratrac, Isspro tri-pod EGT, fuel, and boost, Eclipse CD, 8' Boss snowplow
Fuel Heater Deleted! KORE dual Heim Joint end links waiting to go in
2004 F-250 Powerstroke aFe stage II, Hypertech PTM, Recon mirror markers, Firestone airbags w/ compressor, Rancho 9000's on all four w/ myride, 20" Pacer on 33/12.5 Nitto Mud Grapplers, Eclipse CD, 8' Boss snowplow
Blizzard IceChaser 1.5 cubic yd. poly salt and sand spreader!
Diesel Duo is offline
best bang for the buck? sexytrkr 2003-2007 6.0L Power Stroke 10 02-09-2009 03:59 AM
Best bang for the buck? WITCHGRASSAT282 5.9L Cummins 12 Valve (1994-1998.5) 5 09-29-2007 12:24 AM
Best bang for my buck?? 99fordtruckguy 1994-2003 7.3L Power Stroke 4 08-13-2007 01:57 PM
Best Bang for the Buck Aftermarket upgrade TallCountry Duramax 2006-2007(LBZ & LLY) 9 02-21-2006 10:41 PM
Best Oil Bang for my Buck AUGSX 2003-2007 6.0L Power Stroke 32 01-18-2006 02:34 PM
