skipping a gear? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fieldstruck, this thread has received 3 replies and been viewed 1462 times.
post #1 of 4 (permalink) Old 12-23-2009, 07:39 PM Thread Starter
fieldstruck
skipping a gear?
i have an 07 f250. i have and sct tuner and i recently bought some tunes from elite diesel. the power is great but on the insanity file it almost feels like its skips a gear. it goes throgh first and second good and when it tries to go in third it just bogs down until the rpms get back up. any thing i can do to fix it my self or do i need to get another tune? thanks
fieldstruck is offline
post #2 of 4 (permalink) Old 12-23-2009, 10:11 PM
HalfAst Racing
skippy's Avatar
Images: 1
how long was the tune in the truck when it did it?theres a learning period for the tranny shifting every time you reload a tune.the bogging you feel is probably the truck defueling for the shift.take it easy while the tranny learns or you can smoke the clutches.you cant just tune it and stand on it,you need to make several runs through all gears at light,moderate,and heavy throttle to give it time to learn shift timing and pressures.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
The Following User Says Thank You to skippy For this addition to TDG:
fieldstruck (12-25-2009)
post #3 of 4 (permalink) Old 12-23-2009, 11:03 PM
I would take a guess that its probably not skipping a gear rather its probably aggressive torque converter lock up that you may not be used to. Mine bogs down the same way you describe if I'm not WOT with a race file. I think its a bit annoying thats why I dont run a race file as my daily driver.
Kiddyextreme is offline
The Following User Says Thank You to Kiddyextreme For this addition to TDG:
post #4 of 4 (permalink) Old 12-23-2009, 11:13 PM
********* and Mafia #90
Bcarriveau's Avatar
insantiy file is a race file, ment for track racing.. That should say it all Street race files will be faster for road racing when already rolling.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
What gear oil to use? BEHR2010 5.9L Cummins (2003-2007.5) 4 06-04-2009 03:45 PM
To re-gear or not to re-gear, that is the question Lonesome7.3 1994-2003 7.3L Power Stroke 99 02-28-2008 06:05 PM
Skipping/Hopping on Concrete Freeways IdahoF350 General Ford Truck and Excursion 8 06-01-2007 07:00 PM
Top Gear FireRescuePSD The Parking Lot 7 02-10-2006 04:48 PM
fifth gear nut 350FORD 5.9L Cummins 12 Valve (1994-1998.5) 6 02-01-2006 08:35 PM
