ERIC, I need your help. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coolinthewoods, this thread has received 7 replies and been viewed 1029 times.
post #1 of 8 (permalink) Old 01-02-2010, 05:26 AM Thread Starter
Coolinthewoods
coolinthewoods's Avatar
Hey Eric, I own a 03 6.0 with ARP head studs, EGR Delete, no cat or muff and a intake. I'm running your extreme race tune and its great, but At ten pounds of boost going up a slight upgrade it starts turbo farting, I have to get into the throttle to make it power threw it. Is this a tune thing or is it my truck. I rebuilt my turbo when we did the head gaskets 8000 miles ago, so I don't think its a vain issue. hit me back with any ideas, I would be great full for it. Thanks Jesse Pearson
2003 F-250 XLT 6.0 POWER STROKEN DIESELAFE intake, 4inch mbrp,no kitten or muff,single 5inch stack,banks high ram intake,EGR DELETE,ARP STUDs,SCT live wire with Erics race tunes.8" rough country lift Proud to be an ALASKAN even though it sucks to order parts and to pay more for shipping then the parts are worth.
coolinthewoods is offline
post #2 of 8 (permalink) Old 01-03-2010, 05:45 AM
You can call me French
6.0turbodiesel03's Avatar
Your nest bet would be to eithe E-mail him or call him. He is a very busy person and I doubt he gets on here much.
-French
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
6.0turbodiesel03 is offline
post #3 of 8 (permalink) Old 01-03-2010, 06:00 AM
********* and Mafia #90
Bcarriveau's Avatar
could be a turbo issue, I believe a faulty EGR valve can cause these symptoms as well.! Try pulling it out and cleaning it well, if its not sealing right it will pop open under boost and cause issues like stated.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #4 of 8 (permalink) Old 01-03-2010, 12:01 PM
Member Since Sept 2007
DevilDocTater's Avatar
Sounds like your VGT Solenoid is on its way out
"The best Battlefield Medicine is firepower superiority and overwhelming violence!"
SLAPS Member #193
Singles Club #212
3rd Degree Master Mason
2004 F-350 6.0 6" suspension lift sitting on 35's 6spd MANUAL 4" Turbo Back Exhaust, AFE Air Box, (ARP Studs, New HG's and Complete EGR Delete by Josh at River City Diesel) Coolant Filter from Dfuser, Stainless Steel Up-Pipe from RCD, 4 gauge pillar with Autometer Phantom Series 1 gauges. Boost, Pyro, Fuel Pressure and Oil Temp. Shimmed FPR. Improved Banjo Bolts. Fabtechs all around with a Procomp steering stabilizer from RCD. SCT X3 tuned by RCD
DevilDocTater is offline
post #5 of 8 (permalink) Old 01-03-2010, 07:13 PM Thread Starter
Coolinthewoods
I don't have a EGR valve anymore, its been deleted. Hmmm VGT solenoid.
post #6 of 8 (permalink) Old 01-03-2010, 09:31 PM
Bcarriveau's Avatar
, oops, i even looked your signature over twice
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 8 (permalink) Old 01-04-2010, 02:25 PM
InnovativeDiesel's Avatar
Images: 1
Agreed, I'd start with swapping out the VVT selenoid since you mentioned it was cleaned a year or so ago.
InnovativeDiesel is offline
post #8 of 8 (permalink) Old 01-11-2010, 03:02 PM
Mine does the same thing occasionally. But this is when it's in OD locked up, and 1500 to 1800 rpm. Feels like it's lugging along and when going up a hill it will fart until I either tap on the brake pedal or get on it a bit. Isn't this a normal part of the tune? I have no other problems.
2007 Ford F350 FX4 Crew Cab long Bed, SCT X3, Innovative Tunes by Eric with Edge Insight and EGT. Magnaflow 4" Turbo back. EGR Cooler blocked off. RCD 2.5 Leveling lift kit, 35/12.5/18" Toyo MT. ARP Studs
Gdief is offline
Where is Eric?? dayusex 2003-2007 6.0 Tuner Forum 2 03-25-2009 10:35 AM
Eric has the bug mrsdmaxallitech Sled Pulling 11 07-27-2007 12:53 AM
Going To See Eric Tonight Rockaholic 2003-2007 6.0L Power Stroke 14 04-27-2007 06:47 PM
Eric Is The Best Once Again Hill Topper Supporting Vendors Forum 1 05-16-2006 08:48 PM
New SCT files sent from Eric and Ted @ ID. ryansdad 2003-2007 6.0L Power Stroke 51 09-15-2005 12:43 AM
