quick question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Powerstroke85, this thread has received 5 replies and been viewed 1208 times.
post #1 of 6 (permalink) Old 01-10-2010, 01:10 PM Thread Starter
Powerstroke85's Avatar
quick question
Hey guys, just got the looney tune yesterday morning and i have always had the rough cold start but this morning was a little diffrent. Went to start the truck and cycled the key and glowplug light went off. started and cut out. cycled the key 2 more times and then started and it stayed started but the normal(clanking sound that diesels make) cold start didnt happen. The motor was actually very quiet. all i could hear was the exhaust. Once the truck started idleing up to warm up it sounded normal. also there was alot of smoke comming out the exhaust. Is this normal with a higher hp tune? Figured all the smoke could be due to the tune but wasnt sure about all the smoke. The temp around here averages about mid 20's to lower 30's at night and i dont have a engine block heater but that is something i will be ordering today. Thanks for all of your help guys!
2008 F-250 CCSB 6.4, H&S XRT PRO, Flo Pro straight pipe, Banks Ram Air Intake, Bullydog GT for Gauges.
2006 F-250 SC 6.0, 33x12.50x18 Nitto Terra Grappler AT's, Edge Insight With EGT Probe, 03 Turbo, MBRP 4 inch turbo back off-road, ARP Studs, DFUSER Coolant Filter Kit, ITP Regulated Return,SCT XCAL2(Vivians Tunes) SOLD.
2003 Yamaha Raptor 660R(sold)
2002 CRF450R
34ft. Carriage 5th Wheel
Powerstroke85 is offline
post #2 of 6 (permalink) Old 01-10-2010, 03:36 PM
lilpooh's Avatar
I had the same problem when I had the older flash with out the heat induction. Also found that the pass side glow plug harness was toast. During the cold weather, with any of my tunes , it has a lite smoke until warmed up.
lilpooh is offline
Powerstroke85 (01-10-2010)
post #3 of 6 (permalink) Old 01-10-2010, 04:13 PM
SledMan's Avatar
I just installed my SCT thursday and loaded the Dfuser Wicked tune, and my truck did the SAME EXACT THING. Usually it starts rough, and rattles like crazy with no smoke. Now when i start it cold, it's quiet...no clattering, and bluish smoke from the exhaust. I'd like to know if this is normal also.
What strategy do you have? Mine is VXCF4NK....which is an older one I have heard. Also heard Ford had issues with this strategy.
2005 250 Super Duty Crew. White and Grey. ARP studs, EGR Delete, and SCT from Vivian. CCV re-route, and 4" Magnaflow turbo back.
Other trucks:1980 KW Ext hood, 1982 Kenworth Cabover Aerodyne (BJ and the Bear) 2000 and 2003 Kenworth W900's. 2003 Pete EXHD. All Caterpillar Power. My 2003 has an MBN I converted to 6NZ. Early 550 file, 211-3025 squirts. 800 cam. Acert twins via custom mount. ARP head bolts.
Transporter and Operator of a Bauer Built Championship Unlimited Tractor Pulling Sled for the United Pullers of the Carolinas, Region IV affiliate of the National Tractor Pullers Association (NTPA), and damn proud of it!!!!
SledMan is offline
The Following User Says Thank You to SledMan For this addition to TDG:
post #4 of 6 (permalink) Old 01-11-2010, 12:00 AM Thread Starter
Ill check my strategy in the morning with the SCT but that could be what is wrong. Thanks for the help guys. If it is a older strategy, what is the worst it will do? I dont have a waranty left on the truck so i would have to pay out of my pocket. Thanks guys!
2002 CRF450R
post #5 of 6 (permalink) Old 01-11-2010, 12:27 PM
I Wanna Go Fast!
brentos's Avatar
go have it flashed to the latest inductive heating flash like stated
brentos is offline
post #6 of 6 (permalink) Old 01-11-2010, 02:44 PM
Just to add, I had the same thing with my 07 with the sct. I did the 4" exhaust and EGR delete. The first morning was in the 20's and boy did it smoke. Scared the hell out of me. I have a pretty new flash on the truck. Eric told me to simply plug it in at night. That took care of the smoke. As for idling quieter. Mine is so much quiter now. I couldn't tell if it was because of the egr delete or the new tunes. I just know that I love the truck the way it is now. Gas mileage still sucks though. Can't get above 14 mpg. Took a long trip and got 16 max.
2007 Ford F350 FX4 Crew Cab long Bed, SCT X3, Innovative Tunes by Eric with Edge Insight and EGT. Magnaflow 4" Turbo back. EGR Cooler blocked off. RCD 2.5 Leveling lift kit, 35/12.5/18" Toyo MT. ARP Studs
Gdief is offline
Quick GPR question Zaairman 1994-2003 7.3L Power Stroke 8 02-03-2009 02:22 AM
Quick Question SKJDura6.6 Duramax 2001-2004 (LB7) 4 03-21-2008 05:29 PM
quick question! shadowgearx 5.9L Cummins 12 Valve (1994-1998.5) 4 02-05-2008 03:01 AM
quick question GMguy1234 Duramax 2006-2007(LBZ & LLY) 1 06-10-2007 05:42 AM
Quick SCT question nevrenufhp 2003-2007 6.0L Power Stroke 5 10-03-2005 04:31 AM
