Lower boost after egr fix? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by FAST250, this thread has received 5 replies and been viewed 976 times.
post #1 of 6 (permalink) Old 01-17-2010, 01:51 PM Thread Starter
So I just turned 100k on my 06 and decided to do some major preventative maintenance. I fixed the EGR "Liberator", studs, cleaned ebp tube and sensor, new oil rail plugs, rebuilt oil cooler, turbo boot, serpentine, 3.5 downpipe.
After all that I dropped down to about 20-22psi of boost from 30psi for the last 100k. Checked the boots and all is OK. I called liberator and they said it is not uncommon to see this depending on the programming. They said it is probably flowing more air since the new up pipe to the turbo does not have the scoop and it is more efficient now? The power is the same I think. The boost gets to 22-24 with an extreme tune in. Does this make sense to you guys?
FAST250 is offline
post #2 of 6 (permalink) Old 01-17-2010, 04:40 PM
DieselKid's Avatar
Send a message via AIM to DieselKid
I can see it happening. Without the EGR there, the pcm is commanding the veins to be in a different position. This is probably what is causing your different boost numbers.
08 Mitsu Evo X - SOLD
2003 F-250 6.0L - SOLD
2000 F-250 7.3L - SOLD
Engineering Co-op at Navistar(International)
DieselKid is offline
post #3 of 6 (permalink) Old 01-17-2010, 05:04 PM Thread Starter
Should I just run it? I plan on running my extreme street tune most of the time. I feel as though I am missing out on some power or efficiency with the lower boost.
FAST250 is offline
post #4 of 6 (permalink) Old 01-17-2010, 05:16 PM
Super Moderator
John_G's Avatar
Your truck has a "Mass Air Meter" that the PCM uses to control fueling, so boost has little impact.
You cleaned the EBP tube, if it had been plugged or restricted, the PCM would not have known that desired EPB (turbo drive presssure) had been reached so it would not have adjusted the vanes to a more open position which in-turn would explain your previous higher boost pressure.
Boost is NOT what you want to see, but the actual amount of air entering the engine (Mass of air), you may actually be getting more air now than before but we can;t know for sure.
I vote for LIBERTY!
John_G is offline
The Following User Says Thank You to John_G For this addition to TDG:
DieselKid (01-18-2010)
post #5 of 6 (permalink) Old 01-17-2010, 05:21 PM Thread Starter
I would not be surprised if it was pushing more air. The first time I installed the Extreme tune it blew off the drivers side intercooler tube for the first time and the smoke seamed less than before.
FAST250 is offline
post #6 of 6 (permalink) Old 01-17-2010, 05:31 PM
Its the PCM sensing the EGR not working, people call this the EPA mode where it goes do different turbo positions and fueling to reduce emissions with the EGR off. A custom tune with EGR off should fix your problem, but running it that way should hurt anything. I checked mine EGR on and unplugged and didn't see any mileage differences. It limits the turbo range, so you get a little more boost down low and less up top.
cartmanea is offline
higher egt's and lower boost after EGR block off plates, normal? fearsno1 2008-2010 6.4L Engine Tuner Forum 4 12-30-2009 12:23 AM
best way to lower the rear? Sabbath5.9 Dodge Suspension 6 09-13-2009 04:05 AM
lower valance Superstroker General Ford Truck and Excursion 1 01-30-2009 04:56 AM
lower EGT's Onebadtruck 24 Valve Performance 11 04-24-2008 10:16 PM
Lower it or leave it? Mr Mooring Products General Ford Truck and Excursion 2 05-02-2007 03:43 PM
