Need some info on codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 6 replies and been viewed 692 times.
post #1 of 7 (permalink) Old 01-18-2010, 03:03 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
2004 Excursion, just put a bullydog pmt on and read the codes on the truck and wanted to see if anything to worry about..
Internal control module keep alive memory
FICM performance
Injector circuit low all 8 injectors
I know the circuit low codes is from the FICM. I guess the ficm might be going south? He said its still been starting up fine and its been plenty below freezing here so its not all the way bad or anything yet..
Thanks guys
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 7 (permalink) Old 01-18-2010, 04:51 PM
Super Moderator
John_G's Avatar
The first thing so suspect is a power or gound issue to the FICM as all the codes reported are voltage related.
I vote for LIBERTY!
John_G is offline
post #3 of 7 (permalink) Old 01-18-2010, 05:10 PM
SLAPS President
teamroper60's Avatar
Images: 9
The FICM is taking a dump. Time to either fix it or replace it...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #4 of 7 (permalink) Old 01-19-2010, 03:46 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
well he isnt having any problems with cold start or miss so its not very weak... mine wouldnt start at less than 55 degrees without being plugged in when my ficm went out and a buddys truck was missing on 4 cyl when his went out... he is having zero running issues even when cold... i told him his ficm is probably getting weak but he has time to save up for one since its still running fine.. would all 3 codes be related to ficm or is the internal memory something else...?
Previous Rides:
post #5 of 7 (permalink) Old 01-19-2010, 04:32 PM
strokin6L's Avatar
My buddy's '05 was the same way Darin. I had to keep deleting the CEL everytime he drove it cause it would always throw a CEL for all 8 injectors and the FICM. His truck would start and drive fine also. Took it to ford to replace the FICM under warrenty and no more CEL's for the injectors. I'm betting that the FICM is starting to take a dump.
strokin6L is offline
post #6 of 7 (permalink) Old 01-19-2010, 04:38 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
ya thats what i figured.... thanks chris! his is 04 with 120K tho so no warranty.. prolly gonna wait till has some physical symptoms or saves up money before replacing though.. what bout the internal memory code..?
also, what do they do when they rebuild them? is it just repairing the circuit board or they replace it?
Previous Rides:
post #7 of 7 (permalink) Old 01-20-2010, 12:50 PM
strokin6L's Avatar
Not sure about rebuilding. The only thing i know is that Swamps Diesel Performance in TN solders the joints and also solders in a resister. But as far as rebuilding them or the circuit board...haven't heard of anyone doing it. It's probably just best to get a new one once it takes a dump.
The Following User Says Thank You to strokin6L For this addition to TDG:
6L strokin (01-21-2010)
Codes? tbroadus_41 5.9L Cummins (1998.5-2002) 4 03-03-2008 12:46 AM
DTC Codes DesertSands 2003-2007 6.0 Tuner Forum 2 01-31-2008 12:34 PM
MIL and Codes nplake 5.9L Cummins (2003-2007.5) 1 01-30-2008 04:42 AM
Help with these codes? astro 1994-2003 7.3L Power Stroke 2 01-24-2008 04:11 AM
codes? imported_fast_and_furious 2003-2007 6.0L Power Stroke 4 08-19-2007 01:49 AM
