Whats your boost at???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sjladd6_0L, this thread has received 4 replies and been viewed 999 times.
post #1 of 5 (permalink) Old 01-25-2010, 02:58 PM Thread Starter
Well just got finished installing my mbrp exhaust and i love it. I went with the turbo back off- road cool duals. Thats right no cat the muffler doesnt look like it holds anything back.
O.k so with my intake i noticed that when at wot my turbo would get up to 17-18 pounds of boost. And now after the exhaust was put on i am noticing on the sct that when at wot the boost gets up to 28-29.
Is this normal?
sjladd6_0L is offline
post #2 of 5 (permalink) Old 01-25-2010, 03:51 PM
lilpooh's Avatar
On a stock set up you should see 26-28psi at WOT, your turbo might need cleaning. Keep an eye on boost for a couple of weeks an see if it drops again. Also the IC boot coming off the turbo is known to rip. Sometimes the rip can be under the clamp, so it's best to remove and inspect.
lilpooh is offline
sjladd6_0L (01-25-2010)
post #3 of 5 (permalink) Old 01-25-2010, 04:53 PM Thread Starter
o.k so i have had the turbo out before when i did my head studs. The turbo then looked clean to me, but i am no expert.
How would you "CLEAN" a turbo?
post #4 of 5 (permalink) Old 01-25-2010, 06:57 PM
lilpooh's Avatar
https://www.thedieselgarage.com/forum...ht=clean+turbo
2004 F350 CC DRW King Ranch
lilpooh is offline
sjladd6_0L (01-26-2010)
post #5 of 5 (permalink) Old 01-26-2010, 03:26 AM
Slow 6.0
30 is the max i see at wot 22 the lowest. depends on rpms and what gear the truck is in
2006 F350 XLT 4x4
SICKS-O is offline
hey whats up fastback6225 Introductions 20 09-09-2009 01:45 PM
Raising Boost, Meth Injection, Boost controllers, etc.... Stinger23 1994-2003 7.3L Power Stroke 14 04-15-2008 10:35 PM
Turbo Boost No Boost Burner718 1994-2003 7.3L Power Stroke 16 04-02-2008 05:14 AM
Whats going on? blackcloudCTD95 The Parking Lot 21 08-22-2007 10:19 PM
Boost Problems... Whats Wrong??? BlackSuperStroker33 2003-2007 6.0L Power Stroke 2 02-01-2006 06:36 AM
