egr cooler - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroke this, this thread has received 16 replies and been viewed 2539 times.
post #1 of 17 (permalink) Old 02-01-2010, 04:00 PM Thread Starter
egr cooler
what is the cheapest way to delete the egr cooler
06 4dr f-350 lariat with 8.5in lift 20x14 welds 37in tires, sct with dj's tune straight pipe recon lights, HIDs
stroke this is offline
post #2 of 17 (permalink) Old 02-01-2010, 04:05 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
weld up both ends of it.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 17 (permalink) Old 02-01-2010, 10:20 PM
Send a message via AIM to XxApollynxX Send a message via Yahoo to XxApollynxX
Yup, take it off and weld plugs into both ends of it and be done with it.
2004 Ford F350 Superduty 4X4 XLT C/C S/B:
Just some stock junk! I swear!
20% Front Tint, LED License Plate Lights, Smoked Taillights/Third Brake Light, Silverstar Reverse Lights, www.thedieselgarage.com sticker!
XxApollynxX is offline
post #4 of 17 (permalink) Old 02-01-2010, 10:28 PM
That's what I'll be doing eventually
cartmanea is offline
post #5 of 17 (permalink) Old 02-08-2010, 03:16 AM Thread Starter
going to ford next week to get some studs put in and havind the egr weld. thnks for the info
post #6 of 17 (permalink) Old 02-08-2010, 09:32 PM
This is what the Ford tech told me to do
2006 F250 6.0 Crew Cab King Ranch 4x4
SCT XCAL2
Edge Insight
Kitty ran away
jayman69 is offline
post #7 of 17 (permalink) Old 02-09-2010, 06:44 PM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
I got a bad cooler from the dealer to weld up. Seemed the cheapest route and pretty bullet proof
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #8 of 17 (permalink) Old 02-10-2010, 11:19 AM
The best thing is to have it completely removed, but that isn't the cheapest way to go! I had the plugs put in mine. Great way to go. Also, if you have warranty on the engine still, there is no way to detect it unless someone goes looking for it. Don't forget to get the egr turned off by your tunes if you have it. Keep in mind, if you are in the Winter States you'll have to plug your truck in at night. It blows quite a bit more smoke in the morning if you hadn't plugged it in, although I'm not to sure if that's a result of the egr block off or the tunes. I did both at the same time.
2007 Ford F350 FX4 Crew Cab long Bed, SCT X3, Innovative Tunes by Eric with Edge Insight and EGT. Magnaflow 4" Turbo back. EGR Cooler blocked off. RCD 2.5 Leveling lift kit, 35/12.5/18" Toyo MT. ARP Studs
Gdief is offline
post #9 of 17 (permalink) Old 02-10-2010, 04:40 PM
Bigking's Avatar
I ordered the complete delete kit from River City for $350, They said over time the welds will eventually leak by.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #10 of 17 (permalink) Old 02-10-2010, 04:57 PM
I don't see how if they are good welds.
EGR cooler delete + new oil cooler= no boost barnbridge 2003-2007 6.0L Power Stroke 4 11-06-2009 04:28 AM
6.5-T oil cooler turned into 4L80E cooler ! M123KT-450 GM Transmissions 8 09-03-2009 04:34 AM
Adapting oil cooler to trans cooler 4L80E. . . M123KT-450 GM Transmissions 16 08-15-2009 11:44 PM
Brand New Oil Cooler & Egr Cooler For 6.0 760 PSD Whats Been Sold 2 03-17-2008 03:07 AM
Would Banks Techni-cooler Help Save The Egr Cooler From Failing? nemotorcars 2003-2007 6.0L Power Stroke 9 01-01-2008 09:42 PM
