Dang sct - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jayman69, this thread has received 17 replies and been viewed 2073 times.
post #1 of 18 (permalink) Old 02-02-2010, 12:07 AM Thread Starter
Dang sct
Well I finally got my used XCAL2 in the mail today. Supposed to have 4 unlocks on it and of course be unlocked from the prior vehicle. I open it up and to my surprise it only has 2 unlocks left and the Status is Program Failed..........dang. I spoke to SCT and they said it needs to come back to them. I did not ask them about clearing all of the other unlocks (so it is fresh again) but will tomorrow. They said at least $75 to get it usable. The seller did paypal me the $75 to cover it but now I am at the mercy of SCT. Has anyone sent theirs off to get it cleared? If so how long did it take to get it back? I only paid $160 shipped plus I just got a $75 credit so hopefully I will still make out but what a mess.
On a side not I got the kitty gutted and removed the muffler. This was a great mod...def spools faster and has a great sound but with the windows up you can barely tell a difference .
Rant over......
2006 F250 6.0 Crew Cab King Ranch 4x4
SCT XCAL2
Edge Insight
Kitty ran away
jayman69 is offline
post #2 of 18 (permalink) Old 02-02-2010, 12:16 AM
New Dude her in da garage
Send a message via Yahoo to fredz04f250
How did you clear out the cat?
fredz04f250 is offline
post #3 of 18 (permalink) Old 02-02-2010, 12:18 AM Thread Starter
I paid to have it done......not to sure
SCT XCAL2
Edge Insight
Kitty ran away
jayman69 is offline
post #4 of 18 (permalink) Old 02-02-2010, 12:53 AM
strokin6L's Avatar
a long pry bar works good to smash the packing out of the converter.
strokin6L is offline
post #5 of 18 (permalink) Old 02-02-2010, 12:55 AM
Bigking's Avatar
Thats what I did to mine. Stood it up in a bucket and started ramming a steel rod in it untill I broke it up and dumped it out.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #6 of 18 (permalink) Old 02-02-2010, 01:17 AM Thread Starter
Anyone know if tuners can unlock the xcal for a fee? After looking on SCT's site I found this...but the stats do not match what mine says .....Program Failed
FOR THE X2 9400 AND THE SF 9415:
* Power up the device by plugging in to either a vehicle's OBDII port or a computer's USB port. (usb cable not included)
* Once powered up, scroll all the way down to device info.
* Press select, this will display firmware version and serial number.
* Press select again, and this will display the Tuner Status.
* NOTE: If it does not take you to the Tuner Status Window, and instead kicks you back to the Device Info Screen, Your Firmware is Old and will Need to be Updated to check the status. There is an FAQ section for this. Status will either be: Stat=Stock, Stat=Aftermarket, or Stat=Unused.
*This is the breakdown of what each one means:*
* Stat=Stock - Your tuner is half locked, but fixable. Go the the tech support page, select the Ford Xcalibrator 2 in the first drop down, select Device Update Software in the second drop down and hit Search. Download Liveload 3 by clicking the "Click Here to Download" next to it. Install this application, once installed open it up, plug in the X2. The program asks the X2 to be on the main menu. Program Vehicle is the main menu of the X2s. Press the unlock button within the liveload application. This will change the status to Unused and the tuner will then be ready to tune a new vehicle.
* Stat=Aftermarket - The vehicle is VIN locked, you need to either return the vehicle it is currently locked to back to stock, or you will need to call Tech Support and Get a Return Authorization, send it the Device and pay an Unlocking Fee.
* Stat=Unused - Your tuner is not locked, go tune.
SCT XCAL2
Edge Insight
Kitty ran away
jayman69 is offline
post #7 of 18 (permalink) Old 02-02-2010, 01:22 AM
********* and Mafia #90
Bcarriveau's Avatar
Not sure what Programe failed is..
What is yours!
Stat=Stock, Stat=Aftermarket, or Stat=Unused. Or will it not get that far?
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #8 of 18 (permalink) Old 02-02-2010, 01:23 AM Thread Starter
It goes there but the stat=program failed non of the other three
SCT XCAL2
Edge Insight
Kitty ran away
jayman69 is offline
post #9 of 18 (permalink) Old 02-02-2010, 02:37 AM
vcassens's Avatar
when I did the exhaust on my F 150 I just cut the openings so a pice of 3 inch exhaust pipe wold fit inside and cut teeth on one end and drilled a hole on the other end to put a bar through and just clamped the cat in a bench vice and cut a hole through and left the pipe in it and cut the ends smoth and welded the cat and pipe togeather so that during inspection they couldnt tell they even taped on it with a small hammer and couldnt tell that it wasnt working right
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #10 of 18 (permalink) Old 02-02-2010, 02:39 AM Thread Starter
Smart thinking...if we go back to emission test here in FL I will just go get a used cat and put it on for the inspection
SCT XCAL2
Edge Insight
Kitty ran away
jayman69 is offline
Dang im old... blackcloudCTD95 The Parking Lot 22 06-09-2009 03:37 AM
Dang It...Here Comes The Mud bigdraft The Parking Lot 16 03-21-2009 01:02 AM
man dang it.. newtodiesel The Detailing, Paint & Bodyshop 8 01-28-2009 01:44 PM
Dang it! Dang it! Dang it! imported_STANG302 5.9L Cummins (Pre 1994) 1 09-24-2007 06:08 PM
Dang CPS Kip 1994-2003 7.3L Power Stroke 4 09-15-2007 02:23 AM
