600 HP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 23 replies and been viewed 12706 times.
post #1 of 24 (permalink) Old 02-04-2010, 06:27 PM Thread Starter
vcassens's Avatar
600 HP
what will it take to get 600 rwhp on fuel only and is it posible on the stock turbo I asume biger injectors but what size? I am planing on doing some mods come spring wich include biger injectors, fuel system, egr deleat, and studs all with coustom tuning what do you all recomend for the size of injectors I am staying with the stock turbo for a little bit but do plan on upgrading within 6 months of injectors any input wold be great thanks
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 24 (permalink) Old 02-04-2010, 06:48 PM
SLAPS President
teamroper60's Avatar
Images: 9
I am certainly no expert but I don't think you can hit 600hp on the stock turbo on just fuel.....
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
The Following User Says Thank You to teamroper60 For this addition to TDG:
vcassens (02-04-2010)
post #3 of 24 (permalink) Old 02-04-2010, 06:52 PM Thread Starter
vcassens's Avatar
I do plan on upgrading the turbo wthin 6 months of injectors so what size sould I look at for injectors and turbo for that number also what is the max HP with the stock turbo
singles club #206
bomb squad #67
vcassens is offline
post #4 of 24 (permalink) Old 02-04-2010, 08:45 PM
SLAPS President
Images: 9
Again, I am not an expert on this topic, so hopefully some others with more knowledge will answer you better than I can but IIRC, Smokeshow was at about 600hp on 205's and a bigger turbo (but I don't know what size it was)..
From what I have been told, just shy of 500hp is about the max with the stock turbo... To go higher than that, you need more air than it can provide....
I have also been told that anything much over a 155 injector will do ugly things to your stock turbo (again, that is what I have been told, I have no first hand experience with it), so you might be better off to wait until you are ready to do the turbo before doing injectors, so you aren't spending even more money......
#43
post #5 of 24 (permalink) Old 02-04-2010, 09:41 PM
You can call me French
6.0turbodiesel03's Avatar
600hp on fuel on the stock turbo is inpossible with a 6.0L. Now if we had common rail fuel systems and a better VGT turbo like the D-max's it would be possible. Back to your topic though, for injectors your going to want 190cc - 205cc range and for a turbo, I would go with Trusted Perfomance and their 64mm turbo. That should put you right around your 600hp goal. Keep us posted on what you decide to do!
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
6.0turbodiesel03 is offline
post #6 of 24 (permalink) Old 02-04-2010, 09:46 PM
It is possible with Nitrous.....
225 sticks
ID tune from Eric
200 shot of Nitrous
Intercooler, Intake, Exhaust etc etc....
possibly get ported heads
look into a new intake.....one tuner makes one, but I forgot which one....
03 F250 CC SB 105k on the clock....Extreme Race Tune by ID so far CFM intake elbow and MBRP turbo back exhaust straight out.......WHISTLE......
ChiefMC is offline
post #7 of 24 (permalink) Old 02-04-2010, 10:09 PM
strokin6L's Avatar
you wont get 600rwhp with stock turbo even if you have bigger sticks. You need a full blown fuel system with a bigger fuel pump, 190-225cc injectors, at least a 64mm turbo with good tuning. But you also need other supporting mods for that 600hp. Such as intercooler, studs, egr delete, and a good tranny upgrade.
strokin6L is offline
post #8 of 24 (permalink) Old 02-04-2010, 11:25 PM Thread Starter
vcassens's Avatar
Ok so I have done some reserch and I talked to river city diesel a while back and they sayd I wold be fine with 190mm and stock turbo for a wihle and was told they can be defueled to tow with so I am probably going to go with 180 to 190 injectors but what size turbo will be a good mach for thes that is streatable, towable every now and then and still hook a sled at the county pulls about 3 times a year?
singles club #206
bomb squad #67
vcassens is offline
post #9 of 24 (permalink) Old 02-04-2010, 11:43 PM
strokin6L's Avatar
I was running my 190's with the stock turbo for a while with no issues. If your gonna upgrade both the injectors and turbo...it's best to do the injectors first. For that size of an injector, a 64mm turbo i think will work great. I'm running a 64/71/70 with my 190's.
The Following User Says Thank You to strokin6L For this addition to TDG:
vcassens (02-05-2010)
post #10 of 24 (permalink) Old 02-05-2010, 12:38 AM Thread Starter
vcassens's Avatar
Injectors,fuel system, studs,and egr deleat are going to come first that will break the bank for a while then the turbo will come a few months later but what do all the numbers that I have in bold mean when talking about turbos I dont no that much about turbos thanks
singles club #206
bomb squad #67
vcassens is offline
