SCT Tuner won't load on my truck? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 08F-250, this thread has received 7 replies and been viewed 2083 times.
post #1 of 8 (permalink) Old 02-24-2010, 02:58 PM Thread Starter
I just got a SCT sf3 for my truck and when I hook it up it says vehicle not recognized. I have tried several times calling SCT for tech support but haven't got through yet. The truck did just get out of the shop last week for a new FICM. Is is because they reflashed the truck that it won't work?
08F-250 is offline
post #2 of 8 (permalink) Old 02-24-2010, 10:10 PM
UpstateDieselGuy's Avatar
Sounds like it needs to be unlocked, although the X3's are supposed to unlock automatically. Chris
SOLD
UpstateDieselGuy is offline
post #3 of 8 (permalink) Old 02-25-2010, 12:57 AM
Bigking's Avatar
Did you check to see if you have the same strategy as before? Did you return to stock before you took it in? I am supposed to get mine back tomorrow with studs and egr delete. He said he is going to give me the latest flash also. Mine is at stock, so I hope mine will load when I get it back.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #4 of 8 (permalink) Old 02-25-2010, 03:41 AM Thread Starter
I never had the programmer on the truck before I took it in to get worked on. I got the tuner while the truck was in the shop and took it out of the box last night when I tried to load it.
08F-250 is offline
post #5 of 8 (permalink) Old 02-26-2010, 02:29 AM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
Who did you get it from? According to innovative diesel There is supposidly 2 different sct x3 tuners. One of them will not work on the 08+ trucks. From your screen name I would assume 1. You in the wrong section. 2. You drive a 08+ 6.4 truck.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #6 of 8 (permalink) Old 02-26-2010, 03:17 AM Thread Starter
I don't have the 08 truck anymore, have a 2006 6.0L now. Guess I need a new username.
08F-250 is offline
post #7 of 8 (permalink) Old 02-26-2010, 03:56 AM
Fill out your signature. I'm not 100% on the x3. But go to sct and look thru thr faq's there should be a place on the menu of the tuner that says status. For the x2 it will say stock if the tuner is unlocked and aftermarket if it is locked. Another issue could be that you do not have the latest updates on the tuner which could also give you the same message.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
everything else
post #8 of 8 (permalink) Old 03-02-2010, 04:15 PM Thread Starter
Figured out the problem, they sent me an X3 instead of a SF3.
2006 F250 CC Lariat FX4 6.0
2008 F-250 Lariat 6.4 (Sold)
08F-250 is offline
My truck with a decent load finally!! CumminsCrazed The Parking Lot 14 12-22-2009 06:34 PM
stock truck looking for a tuner FATSO 2008-2010 6.4L Engine Tuner Forum 40 06-24-2009 12:57 AM
Which Tuner do I get for my Truck????? Truckmaniac 2008-2010 6.4L Engine Tuner Forum 41 02-25-2009 12:15 AM
People with DP-Tuner/OBS Truck...help BigRed97 1994-2003 7.3L Chips & Tuners Forum 9 02-11-2007 08:22 AM
sct tuner live link 3 and live load???? hotpursuit 2003-2007 6.0 Tuner Forum 1 12-04-2006 09:07 PM
