6.0 van & truck - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KTMHauler, this thread has received 46 replies and been viewed 3922 times.
post #1 of 47 (permalink) Old 02-25-2010, 04:32 AM Thread Starter
Dirt biker
KTMHauler's Avatar
6.0 van & truck
What is different about the truck 6.0 & Van 6.0 there 50hp shy in the Van
and there both 6.0 will a tuner give the van the same hp gain as a truck or more
KTMHauler is offline
post #2 of 47 (permalink) Old 02-25-2010, 06:35 AM
bushpilot's Avatar
theres a TON of **** thats different...the oil filter is under the truck
the fuel filter changes are a pain, the rear ends are not the same, the
fronts ends arent the same either !
are you talking 4x4 or 2x4 ?
https://www.thedieselgarage.com/forum...er.php?u=22813
Don R.
Truck Audio,
bushpilot is offline
post #3 of 47 (permalink) Old 02-25-2010, 03:43 PM Thread Starter
Dirt biker
KTMHauler's Avatar
the vans have less hp than the truck why is that? I want to put a tuner on the van and what hp gain will the van get? I think the van has 255hp and the truck is 310 I think and both are 6.0
Things i say up here
post #4 of 47 (permalink) Old 02-25-2010, 04:07 PM
bushpilot's Avatar
depending on the year i thought it was "lack of intercooler" related.
Don R.
Truck Audio,
post #5 of 47 (permalink) Old 02-25-2010, 05:55 PM Thread Starter
Dirt biker
KTMHauler's Avatar
it's a 2006 it has a intercooler
post #6 of 47 (permalink) Old 02-26-2010, 12:10 AM Thread Starter
Dirt biker
KTMHauler's Avatar
OK here is horse power for 2006 6.0 motors
The truck is 325hp 570ft and the Van is 235hp and 440ft that is a big difference and both are intercooled 6.0 and a tuner that is set for 80hp
gain So will it bump me up to 405 like it would in the truck or just bump hp to
315? what is still not what the truck has stock I don't get it!
post #7 of 47 (permalink) Old 02-26-2010, 01:35 AM
Sheep Shagger's Avatar
There are tuners / chips programmers out there that will boots the HP and Torque to the stock truck spec's and beyond, since everything is *basically* the same.
But heat is the problem in the van, take a look at your radiators and intercoolers and complete lack of room, then compare it to the equiv Trucks.
I have heard that you can even flash the van with the identical truck tunes, but not sure how true that is.
My 06 is still under warranty and heat is my concern, that and any engine problems mean a body off job on the van. So I have been reluctant to do anything, plus power seems more than adequate for my use.
But if you go this route, you need to phone up and talk to the tuners as none list much for the van on the web.
Sheep Shagger is offline
post #8 of 47 (permalink) Old 02-26-2010, 02:22 AM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
Innovative posted in a forum saying that the intake on the vans is very restrictive. With a tuner, straight pipe and tuning the vans should be faster than the trucks. The vans are lighter.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #9 of 47 (permalink) Old 02-26-2010, 06:17 AM
bushpilot's Avatar
'course they would say that....theyre TRYING to sell you something.
I suggest you go for it, and report back to all the other owners...
dont complain when your out of warranty or broken
Don R.
Truck Audio,
post #10 of 47 (permalink) Old 02-26-2010, 11:53 PM Thread Starter
Dirt biker
KTMHauler's Avatar
If the head gasket blows you have to lift the body to work on it?
My 06 has 60000mi. on it and ford won't touch it
I have a friend who is a ford dealer mechanic and ran the VIN# and nothing is covered and he tells me that all 6.0 motors are gasket blowers and just to be safe bring the HP up to what the F series trucks have and know more and that's 325hp
He said that you cannot flash the van with truck software
I would have to have a custom one done.
Good donor truck for race truck Superdutytd General Ford Truck and Excursion 0 10-07-2009 10:43 PM
stock truck quite/tuned truck loud? rstaichi 2008-2010 6.4L Engine Tuner Forum 16 04-16-2008 03:02 AM
my truck and a buddies truck at ocotillo pics dieselboy740 4X4 Offroad Forum 16 11-19-2007 11:53 PM
had my truck at the local truck pull to night SmokingIDI_7.3L 7.3L and 6.9 IDI (Pre 1994) 3 06-17-2007 07:24 AM
NASCAR Truck Series - Powerstroke truck sredish General Ford Truck and Excursion 14 07-01-2006 01:25 PM
