digital gauge with FP? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 23 replies and been viewed 2926 times.
post #1 of 24 (permalink) Old 02-25-2010, 09:26 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
Is there any digital monitors that you can view fuel pressure for our trucks on? other than the old commander... preferebly one like the edge monitor that just plugs into obdII and just has another pigtail coming off it for the FP like the EGT one.. bout to just order a digital FP gauge but was wanting to make sure an "all in one" gauge wasnt out there..
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 24 (permalink) Old 02-26-2010, 02:23 AM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
I've heard it can be configured into the dash daq with a widget like the egt probe. Might look into that
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #3 of 24 (permalink) Old 02-26-2010, 02:26 AM
********* and Mafia #90
Bcarriveau's Avatar
The PCM doesnt get a Fuel Pressure reading so there will be Nothing to display FP without an added sensor.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #4 of 24 (permalink) Old 02-26-2010, 02:32 AM
strokin6L's Avatar
Bill is right. There is no way to monitor fuel pressure on a powerstroke without putting a sending unit in somewhere. It'd be nice if you could plug something into the OBDII port and get the reading that way, but it just isn't gonna happen.
strokin6L is offline
post #5 of 24 (permalink) Old 02-26-2010, 02:42 AM
I know the fp is not avalible from the obd2 port. The dash daq has to have a added on widget to work the egt gauge on a 6.0. Like I stated before there is suppost to be a way to use a sending unit similar to using a widget for the egt probe. I don't have a dash daq but at one point was looking to buy one for a all in one monitor. Might try and pm nutty at spartan he would probably be able to definatively awnser it
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
everything else
post #6 of 24 (permalink) Old 03-01-2010, 06:44 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
ya i know you can read thru obd... but i was sayin like on the bullydog pmt for instance you plug into obd2 for everything except the egt probe.. so have an extra sender for FP.. but i bought that cyberdyne off jegs for 89.99... should have it installed tom night ill let yall know how it works!
Previous Rides:
post #7 of 24 (permalink) Old 03-02-2010, 12:53 AM
Bcarriveau's Avatar
Everything that can read fuel pressure for the 6L requires the sensor like egt. Sooo... what is it you are asking if you knew already .
Edge makes one, sct live wire, bully dog makes a few i belive. Dashdaq ect.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #8 of 24 (permalink) Old 03-02-2010, 01:16 PM
I Wanna Go Fast!
brentos's Avatar
wow bill you really didnt get what he was asking did you
brentos is offline
post #9 of 24 (permalink) Old 03-02-2010, 03:29 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
lmfao.. i dont think he does brent..
the bullydog, scout, edge, etc are all digital monitors that you can just plug in the obd2 port and read all the permiters through there except egt, fp, etc where you have to buy a sender because factory cpu cannot read those.. however the bullydog, scout, edge, etc. DO NOT have a fuel pressure sender available...!! was wondering if any digital monitor have the FP function even available to add a sender to like the commander used to...
on same page now bill?
Previous Rides:
post #10 of 24 (permalink) Old 03-06-2010, 01:40 AM
Bcarriveau's Avatar
Ah yes i am .
Da Rules..Here
Dear Tequila:
The TDG TOTQ
Need help picking a digital gauge/monitor FSD 5.9L Cummins (2003-2007.5) 8 11-07-2009 05:18 PM
Looking for a Digital Gauge Monitor New 0mega Supporting Vendors Forum 1 09-27-2009 04:28 PM
BD Digital gauges and banks gauge dieselsmoke0204 Whats Been Sold 10 08-03-2009 06:00 PM
Digital SLR GilroyRacing The Parking Lot 12 03-01-2008 04:08 AM
05/06 Digital A/C in an 03? sredish General Ford Truck and Excursion 5 03-31-2006 06:48 AM
