Serious problems! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Super08Duty, this thread has received 12 replies and been viewed 1948 times.
post #1 of 13 (permalink) Old 02-27-2010, 12:24 AM Thread Starter
Diesel Kid
Super08Duty's Avatar
Serious problems!
My buddy has a 2003.5 6.0 with about 120000miles on it. Its had the HG's replaced along with a couple injectors and the HPOP. This was all done about 4 months ago. Last weekend we were coming back from the drag strip on the highway cruising at 75mph. He has an SCT tuner with RCD's Extreme tune, but at the time he had it on the stock tune. Well im driving behind him when he decides to give it a quick punch of the throttle. He throws a pretty good amount of smoke out. Knowing his truck was on a stock tune i figured he broke something. but we keep rolling for about 30 mins. then he gets on the throttle again and this time stays on it. Hes rolling so much smoke he makes 3 cars slam the brakes. i get in front of him and watch as the smoke pours out the exhaust, i noticed that shortly after the smoke came out it would disappear. This is when i realized something is seriously wrong with his truck. The truck wasnt putting out any black smoke....but a ton of white smoke. We get into town and hes about a half mile behind me. he calls me telling me to come pick him up cause the truck wont run anymore. i look in the rear view and see a HUGE wall of white smoke where an intersection should be. little while later i look at the truck and of course its leaking coolant out the degas bottle. this is where im really confused. I look under the truck and the side of the block is completely covered in coolant. the next day i take another look at the truck and theres oil dripping out of the exhaust pipe. What i want to know is what is most likely wrong with the truck? besides blown HGs. thanks.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #2 of 13 (permalink) Old 02-27-2010, 12:30 AM
********* and Mafia #90
Bcarriveau's Avatar
He blew his EGR cooler!
Whats dripping out is because of all the fluid going threw the exhaust and absorbing lots of Soot!
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 13 (permalink) Old 02-27-2010, 08:45 AM Thread Starter
Diesel Kid
Thanks bill. You think its the Head Gaskets too? sense it leaking coolant out the degas, or is that one of the effects of a bad egr cooler?
Colton
post #4 of 13 (permalink) Old 02-27-2010, 01:53 PM
strokin6L's Avatar
if you said that there's oil dripping out of the exhaust pipe, that pretty much tells me he blew the turbo.
strokin6L is offline
post #5 of 13 (permalink) Old 02-27-2010, 03:04 PM
Bcarriveau's Avatar
I'm betting just egr cooler. Won't know untill you pull the valve and look or dig into it.
Are you sure its oil or do you think its soot that got wet.?
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #6 of 13 (permalink) Old 02-27-2010, 08:11 PM
Bcarriveau's Avatar
I agree if it is oil the turbo it is. Th would explain the white white as well!
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 13 (permalink) Old 02-27-2010, 09:30 PM
Tim C's Avatar
If it is in fact oil and not wet soot then also check the oil pressure. After the dealer here in town replaced my egr cooler at 52000 miles years ago I picked the truck up (after two weeks, they messed up the first cooler somehow and pushed the truck outside for a week with the top of the engine torn down while they waited on parts) and on the 20 mile ride back to my house it soaked my other car that a friend was driving for me in oil and was spewing white/blue smoke the whole trip. Oil was leaking from the exhaust and was all over the front of my other car and I had to add 4 quarts to put oil back at the full mark on the dipstick.
Long story short I was building 130 to 150 psi oil pressure and it was spraying out of the turbo into the exhaust. I took the lpop regulator out (12mm hex just behind the crank pulley under the truck) and found it to be scored up. I got a new regulator and spring from ford for $17US (wholesale since im a mechanic I got it from my shop) and I had to replace the y -pipe that their tech broke while doing the egr cooler. With the new regulator the oil pressure doesn't get over 100 psi ever. I took the whole exhaust system off and pressure washed it all out but probably could have just let it burned out. The turbo was fine it didn't leak after fixing the oil pressure problem.
Needless to say I have performed my own work since then even while it was still in warranty (I got 163000 on it now) and refuse to let anyone else work on mine anymore.
2003 F250, 6.0 PSD, 6 Speed, 6.5" Procomp Lift, 35s, SCT Tuner, 4" Turbo back exhaust
1978 F150, 351M, 4 Speed, 6" Lift, Trail Beater on 42s
SINGLES MEMBER #221
AMERICAN CLUB MEMBER #14
Tim C is offline
post #8 of 13 (permalink) Old 02-28-2010, 08:50 AM Thread Starter
Diesel Kid
almost positive it was oil out the exhaust.
Colton
post #9 of 13 (permalink) Old 03-02-2010, 01:13 PM
I Wanna Go Fast!
brentos's Avatar
turbo/egr cooler
brentos is offline
post #10 of 13 (permalink) Old 03-03-2010, 06:26 AM Thread Starter
Diesel Kid
The reason i cant see it being turbo failure is that when the truck was producing all that white smoke....the boost gauge was still saying the turbo was making boost. wouldnt the turbo stop making boost if it died?
Colton
6.0L problems gas/diesel eng rebldr 2003-2007 6.0L Power Stroke 12 04-17-2009 02:09 AM
big problems maybe? mayflower06 5.9L Cummins (1998.5-2002) 3 10-16-2007 12:24 AM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 09:27 AM
Air Bag Problems King of Obsolete Medium and Heavy Duty 10 07-02-2006 06:04 PM
afe problems johnny_dolittle 2003-2007 6.0L Power Stroke 1 03-30-2006 03:06 AM
