SCT question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by newtodiesel, this thread has received 7 replies and been viewed 1098 times.
post #1 of 8 (permalink) Old 03-06-2010, 06:59 PM Thread Starter
PRIVATE PROPERTY-KEEP OUT
newtodiesel's Avatar
SCT question
ok last mid-summer i returned my truck to stock...(i have sct and tunes from dfuser) i went this morning and put tune (dfuser power which have been running for some time now) back on truck...everything loaded fine....went down the road and 3rd to 4th gear is jerking REAL bad then tow haul light starting blinking...stopped and turned truck off and restarted and tow haul light is gone but still jerking something bad...i have no idea how to update SCT even if thats the case...but i can get SCT site to do that if needed.....but any ideas on why its doing this???? BTW i did drive the truck around easy to get the trans to learn tune like i always do....ANY IDEAS???
2004 FORD F-350 FX4 CREW CAB...SINGLES CLUB MEMBER NUMBER 230...BOMB SQUAD NUMDER 30...FARM CLUB ORIGINATOR NUMBER 1....STOP LIVING IN JOHN DEERE GREEN AND COME OVER TO KUBOTA ORANGE..CANCEL MY SUBSCRIPTION CAUSE I DONT NEED YOUR ISSUES!!!!
newtodiesel is offline
post #2 of 8 (permalink) Old 03-06-2010, 07:42 PM
Did you set your revs per mile? If not it will shift like that. Also it takes a bit of driving for it to relearn.
2003 Ford F350 DRW CC LB, H11 studs, 190cc injectors from II,Stage 1 VGT from II, EGR delete, Spearco, Reg Return from dfuser, Magnaflow turboback 4 inch stainless, SCT XCAL3 Tuned by ID, FASS 150/180, 6inch lift, 100 gallon transfer tank, and a bunch of other nic nacs and do dads! DUALLY CLUB MEMBER #74
tattoo6.0 is offline
post #3 of 8 (permalink) Old 03-06-2010, 08:40 PM Thread Starter
i didnt set anything.....it was fine last time i ran the tune....all i did was reinstall it on truck like it was last summer.....as far as driving yes i drove it around easy but the jerking is so bad i didnt wanna tear up tranny.....about the revs.....how do i set that up???
post #4 of 8 (permalink) Old 03-06-2010, 09:58 PM
which sct do you have?
post #5 of 8 (permalink) Old 03-07-2010, 12:52 AM Thread Starter
got the sct x3
post #6 of 8 (permalink) Old 03-07-2010, 11:52 PM
lilpooh's Avatar
https://www.thedieselgarage.com/forum...ad.php?t=72080
2004 F350 CC DRW King Ranch
lilpooh is offline
post #7 of 8 (permalink) Old 03-08-2010, 02:46 PM Thread Starter
ok now im screwed......its doing the same thing now STOCK......but worse....jerking slipping and tow haul light keeps flashing
post #8 of 8 (permalink) Old 03-16-2010, 11:28 PM
mattsn's Avatar
did you have any reflashes done over the winter between when you took the tune out and putting it back in?
might want to try disconnecting the battery for 30 mins see if it resets everything .
mattsn is offline
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 04:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 01:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 01:40 PM
