anyone ever had this happen - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by newtodiesel, this thread has received 25 replies and been viewed 2680 times.
post #1 of 26 (permalink) Old 03-22-2010, 02:16 PM Thread Starter
PRIVATE PROPERTY-KEEP OUT
newtodiesel's Avatar
put tune on truck....drove for a few miles and all of a sudden the trans temp gauge flew though dash and tow haul light is flashing.....it is shifting fine except high gear....wont cause tow light is on.....
2004 FORD F-350 FX4 CREW CAB...SINGLES CLUB MEMBER NUMBER 230...BOMB SQUAD NUMDER 30...FARM CLUB ORIGINATOR NUMBER 1....STOP LIVING IN JOHN DEERE GREEN AND COME OVER TO KUBOTA ORANGE..CANCEL MY SUBSCRIPTION CAUSE I DONT NEED YOUR ISSUES!!!!
newtodiesel is offline
post #2 of 26 (permalink) Old 03-22-2010, 02:22 PM
strokin6L's Avatar
it's an easy fix. Your tranny temp sensor is bad and needs to be replaced. It's very common. Mine did the same thing.
strokin6L is offline
The Following User Says Thank You to strokin6L For this addition to TDG:
newtodiesel (03-22-2010)
post #3 of 26 (permalink) Old 03-22-2010, 02:24 PM Thread Starter
so will this cause the tow haul light to come on and not shift to high gear?
post #4 of 26 (permalink) Old 03-22-2010, 02:26 PM
FFRyan's Avatar
You could have fried your tranny, tow haul is flashing because it is slipping.
2007 F-250 CC SB 4x4
Edge Evolution Tuner, Straight pipe, no kitty and Zoodad mod.
FFRyan is offline
post #5 of 26 (permalink) Old 03-22-2010, 02:26 PM Thread Starter
and where is it at?? is this something i can do myself??
post #6 of 26 (permalink) Old 03-22-2010, 02:27 PM Thread Starter
and FFRYAN if i put it back stock truck shifts fine
post #7 of 26 (permalink) Old 03-22-2010, 02:46 PM
FFRyan's Avatar
what tuner do you have, and does it run noral on stock, no flashing light or anything??
FFRyan is offline
post #8 of 26 (permalink) Old 03-22-2010, 02:47 PM Thread Starter
have x3.....and yea when i put back to stock trans shifts fine and no lights flashing
post #9 of 26 (permalink) Old 03-22-2010, 02:49 PM
FFRyan's Avatar
Could be something in the tune, or the temp sensor ive heard of the sensor going bad an causing some issues. Its scewed into the side of the tranny, i dont know where exactly but their is a few threads on here that may help you/
FFRyan is offline
The Following User Says Thank You to FFRyan For this addition to TDG:
post #10 of 26 (permalink) Old 03-22-2010, 03:54 PM
strokin6L's Avatar
the temp sensor is inside the pan. Gotta drain fluid and take the pan off. you'll see alot of solenoids and sensors in there, i'm not sure which one it is off hand.
Anyone seen this happen?????????????? matty169 Duramax 2001-2004 (LB7) 1 02-17-2010 02:35 PM
Anybody ever had this happen? Lowboy Medium and Heavy Duty 30 10-17-2007 12:05 AM
Anyone had this happen?? nick43 Duramax 2006-2007(LBZ & LLY) 7 04-19-2007 12:04 PM
What would happen if I...... 75867586 2003-2007 6.0L Power Stroke 11 03-10-2007 05:59 AM
Any one have this happen? 30RUM 5.9L Cummins (2003-2007.5) 2 02-15-2007 03:34 PM
