Trouble loading files - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Goosekiller, this thread has received 4 replies and been viewed 1105 times.
post #1 of 5 (permalink) Old 03-22-2010, 10:34 PM Thread Starter
Goosekiller's Avatar
I am having trouble loading files on my SCT. I have the new firmware and i have loaded a ton of files before with no problem. When i saved it off my email i saved it as a zip file which i have no idea what the heck it is. So if you have a clue what i am doin wrong please help thanks a lot.
2001 2500 4x4
Built 12 valve
Goosekiller is offline
post #2 of 5 (permalink) Old 03-23-2010, 01:06 AM
lilpooh's Avatar
I don't know if this will help but, I had a similar issue once. Some how my files got screwed up (kids!). When I contacted sct, I found out that if the file is not in .ll3 format it will not work.
When you look at your files it should have .ll3 to identify it. Example: x-street.ll3
Try to do a search on your pc with any .ll3 attached to it. When and if you find it, it's a good idea to back up those files on a flash drive, just incase your pc takes a dump.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 5 (permalink) Old 03-23-2010, 01:44 AM
Send a message via AIM to birdmann79
You need to extract the file out of the .zip ...the zip file is just the file in a compressed stage to email easier...should be able to right click on the mouse , then choose to extract the file ..i usually just extract it to desktop ..easier to find that way ...
birdmann79 is offline
The Following User Says Thank You to birdmann79 For this addition to TDG:
Goosekiller (03-23-2010)
post #4 of 5 (permalink) Old 03-23-2010, 04:49 AM
Slow 6.0
not all files are .ll3, the latest ones i have received are .cef
2006 F350 XLT 4x4
SICKS-O is offline
The Following User Says Thank You to SICKS-O For this addition to TDG:
lilpooh (03-23-2010)
post #5 of 5 (permalink) Old 03-23-2010, 03:01 PM Thread Starter
I figured it out and this file was a cef i just had to extract the file thanks everyone.
2001 2500 4x4
Built 12 valve
Loading Docks tclapp Everything Else 6 08-25-2009 01:13 AM
Video of Twins Loading CanadianRedneck 2003-2007 6.0L Power Stroke 46 08-08-2009 01:55 AM
Loading up and heading out Billysgoat The Parking Lot 23 03-31-2006 09:36 PM
Loading Sct Tunes birddog55 2003-2007 6.0L Power Stroke 7 03-03-2006 08:40 PM
