06 problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Eric.Larson, this thread has received 14 replies and been viewed 2208 times.
post #1 of 15 (permalink) Old 04-25-2010, 02:19 AM Thread Starter
06 problem
Hello TDG! Well in need of some experinenced wrenchers. Running a juice with attitude mostly level 3 and in the higher rpms at WOT nearing 3400 RPM she makes a little noise...almost like I can feel it in the skinny petal. Any ideas what it might be? Any guidance would be greatly appriciated. Also running AirRaid CAI and MBRP 4" turbo-back...no cat...no muffler. Thanks for the space.
Eric
Eric.Larson is offline
post #2 of 15 (permalink) Old 04-27-2010, 02:31 AM
im running the same in my f350. where is this noise coming from? or can you tell/
crash_7086 is offline
The Following User Says Thank You to crash_7086 For this addition to TDG:
Eric.Larson (04-28-2010)
post #3 of 15 (permalink) Old 04-27-2010, 07:40 PM Thread Starter
Feels like transmission...almost like I can feel it through the gas pedal. Are you having any problems similar? I think that my dad's F350 he had did the samething...I will have to see what he did with his.
post #4 of 15 (permalink) Old 04-28-2010, 01:17 AM
lilpooh's Avatar
If you have the two driveshafts going to the rear, check the carrier bearing for excessive play and worn rubber. Also check the driveshaft u-joints, I had a similar issue and it was the u- joint right after the carrier bearing. One of the caps failed and caused a vibration.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #5 of 15 (permalink) Old 04-28-2010, 01:48 AM Thread Starter
I will check that out....don't really get a vibration but might as well take a look....might just have to take it to the stealership....Edge off...cat in....too much work...
post #6 of 15 (permalink) Old 04-28-2010, 02:01 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
make sure your exhaust isn't rubbing....
2003 F250 "Pulling Truck"
hhrecovery is offline
The Following User Says Thank You to hhrecovery For this addition to TDG:
post #7 of 15 (permalink) Old 04-28-2010, 03:34 AM
I Wanna Go Fast!
brentos's Avatar
does it do it without the edge?
brentos is offline
post #8 of 15 (permalink) Old 04-28-2010, 04:29 AM Thread Starter
Doesn't seem like the exhaust is rubbing anywhere....now gettting a rubbing sound when I turn left....will really have to get under there and check the exhaust out tomorrow. I do get the noise when it shifts when the Edge is in stock...might have to take it out and take it to the dealer. Will post what I come up with tomorrow...thanks for the advice to all.
Eric
post #9 of 15 (permalink) Old 04-29-2010, 02:08 AM
no matter the level i have my edge in my truck starts lurching when im driving between 45 and 60 mph but only when the transmission locks into overdrive gear... does that sound at all similar? i Believe my problem is my egr cooler because it's using coolant.
post #10 of 15 (permalink) Old 04-29-2010, 03:56 AM
SmokeCloud's Avatar
Your EGR cooler has nothing to do with how your transmission shifts, for now go back to stock and see if it still does it. perhaps the shifting points need to be adjusted.
Real Trucks Burn Diesel!
SmokeCloud is offline
help with problem. please,please bigbucks8 2008-2010 6.4L Power Stroke 4 12-03-2009 03:30 PM
Got a problem....... KeyserSozae 6.5L Diesel Engine 17 01-22-2008 02:22 PM
1 new problem, 1 old problem, 1 problem fixed LOL Liftedpsd 2003-2007 6.0L Power Stroke 16 04-23-2007 01:13 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 04:35 PM
New problem now... Extended Power General Parts and Accessories 5 10-26-2006 03:16 AM
