SCT flash - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KTMHauler, this thread has received 15 replies and been viewed 2258 times.
post #1 of 16 (permalink) Old 05-06-2010, 08:35 PM Thread Starter
Dirt biker
KTMHauler's Avatar
SCT flash
I got a SCT X3 3000 from INNOVATIVE for my VAN i got 3 tunes
1st one a just a economy no power (wrong it hauls *** and mileage not good) i would say 80hp more
2nd is for tow, what really hauls *** and shifts hard and this one about 120hp more
3rd tune is street, now that one will smoke both wheels threw 3 gears without
doing a brake stand and this one i don't know how much hp 200hp? but it has been awhile since my knees were shaking
did i get a tune for a VAN or a TRUCK i think truck is what ever tunes + 80hp
I raced a truck with 6.0 on econo tune and flat out kick his but bad
Things i say up here
KTMHauler is offline
post #2 of 16 (permalink) Old 05-06-2010, 11:10 PM
If your three tunes are custom ones you should have had to give innovative your engine strategy codes and when they build the tunes they are made specific for your vehicle. I recently got custom tunes from Eric and I didn't bother with an economy tune. If I drive normal with my extreme street tune on I am getting around 21-22mpg and tons of power
crankytrucker is offline
post #3 of 16 (permalink) Old 05-06-2010, 11:32 PM Thread Starter
Dirt biker
KTMHauler's Avatar
See i cannot drive normal
and i have stock head bolts
Street tune is about 375 400 rwhp
Yep i gave INNOVATIVE the strategy codes
post #4 of 16 (permalink) Old 05-07-2010, 12:11 AM
I would be careful with your bigger street tunes without studs and I'm guessing no egr delete. I would only work it hard for short periods or the high egts and cylinder pressures will blow out head gaskets easy. And the added fuel creating lots of smoke will plug off egr cooler causing heat flashing in coolant and pressuring up cooling system also blowing out head gaskets. If you check out mkmcustoms.com they have arp stud kits and egr kits for very reasonable prices. Have fun
post #5 of 16 (permalink) Old 05-07-2010, 12:53 AM Thread Starter
Dirt biker
KTMHauler's Avatar
The EGR is turned off if that helps
I have a SCT Dashscan with probe coming so i know what the egts are
and doing studs is pulling engine out If it happends i quess that is what i got to do
post #6 of 16 (permalink) Old 05-16-2010, 07:11 PM Thread Starter
Dirt biker
KTMHauler's Avatar
I got the DashScan and the EGT senser and plug just broke off in the monitor
never even installed it can't use it What a P.O.S. plug i would not stay in? it has release buttons on the plug but you don't need them the wire just falls out
So what ever i will ziptie the wire to the big wire to keep it from falling out
and then i look in were the socket is and it is not in there? It's on the plug now
post #7 of 16 (permalink) Old 05-16-2010, 08:28 PM
Stuck in Commiefornia...
IdahoF350's Avatar
If I remember correctly the vans are only rated at 235hp, and trucks were 325hp. So in theory, a 40hp tune based on truck tuning would be 130hp in a van. A 120hp file from a truck would be 210hp in a van. IIRC, the lower rating on the vans was due to a lack of an intercooler. I could be totally wrong on the intercooler and base power level, but I know vans are rated at a lower power level to begin with.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #8 of 16 (permalink) Old 05-16-2010, 09:17 PM Thread Starter
Dirt biker
KTMHauler's Avatar
I asked innovative what HP did they give me 3 tunes economy what is no power just better MPG Tow 310wrhp and street 375wrhp
But every time i change it back and forth to see what HP changes
and i go back to street but it is not the same Now power comes on higher up in the rpms and trany does not shift as hard like stock is
The day i first put the tune in i chirped the tires in two gears not now
something is up with tuning do i have to put it back to stock first then
chose a different tune
I put it on econo and it still hauled butt so i put it back to street no change
so i put it back to stock till i got the Dashscan what broke before i even
went out side to install it P.O.S. plug
It's been a week and no word from SCT so i guess i toss it in the garbage
post #9 of 16 (permalink) Old 05-18-2010, 03:10 PM
InnovativeDiesel's Avatar
Images: 1
When you first install the program, you have to drive it for about 50 miles or so before it will completely learn. Once learning is done, the power and shifting will settle in.
SCT will send you a replacement part. If you have trouble getting through, contact them through the live chat at the bottom of this page: http://www.sctflash.com/contact.php
InnovativeDiesel is offline
post #10 of 16 (permalink) Old 05-18-2010, 04:21 PM
strokin6L's Avatar
is this hand calculated cause never heard of anyone getting that kinda milage with a 6L even highway driving.
strokin6L is offline
To flash or not to flash, that is the question... 444turbodiesel 2003-2007 6.0L Power Stroke 5 05-22-2009 08:19 PM
Flash 08-25-7 Demolition 2008-2010 6.4L Power Stroke 3 12-29-2008 09:58 PM
2005...To Flash or not To Flash tstc 2003-2007 6.0 Tuner Forum 9 03-21-2008 11:03 PM
Flash Help imported_newtodiesel 2003-2007 6.0L Power Stroke 9 12-17-2007 07:26 PM
flash or no flash is the ? Bcarriveau 2003-2007 6.0L Power Stroke 15 09-13-2007 06:31 AM
