Tuner with pilot injection active - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rtm038, this thread has received 8 replies and been viewed 3094 times.
post #1 of 9 (permalink) Old 05-11-2010, 08:10 AM Thread Starter
Hello all,
Is there anyone running a tuner that has pilot injection active? If so, what tuner? How many miles since installation? Any problems so far?
Thanks
Ryan
2006 F-350 Crew Cab, shortbed, SRW, 6.0 PSD/auto, 4x4, Lariat, White/Tan, 3.73 L/S, ESOF, moonroof, RECON smoked 3rd brake light, cab lights & mirror signal lights and more to come. Pics
rtm038 is offline
post #2 of 9 (permalink) Old 05-12-2010, 02:49 PM
InnovativeDiesel's Avatar
Images: 1
Ryan,
We can turn on PI on some strategy's. Not all of them will support it. Ford used the older PI tables for other control.
InnovativeDiesel is offline
post #3 of 9 (permalink) Old 05-12-2010, 05:25 PM
Eric, does PI have any negative effects, like increased injector wear since they are firing twice instead of once? Also, can it lead to more problems later on when you start having stiction problems? I'd love to make mine quieter when I get tunes from you, but only if there are no negative effects. Thanks!
cartmanea is offline
post #4 of 9 (permalink) Old 05-12-2010, 07:11 PM
Images: 1
I'm actually not sure about long term wear. I have customers that have been running PI since 2003 and haven't had any complaints. Personally, I don't care for PI on the 6.0L very much. The transition from PI to standard Injection is less than smooth and noticable, especially on a higher power tune. On a near stock tune, it's not bad.
post #5 of 9 (permalink) Old 05-12-2010, 07:41 PM
Does it only do PI at idle with no throttle input?
post #6 of 9 (permalink) Old 05-12-2010, 07:45 PM
Images: 1
You can do that, but I usually run it up to 1200rpms, so you don't feel it taking off.
post #7 of 9 (permalink) Old 05-12-2010, 07:49 PM
Oh ok, thanks for the info!
post #8 of 9 (permalink) Old 05-26-2010, 07:23 PM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
Cartmena. Doug @ gogo said he was using pi on his truck. Might be a good person to ask about it.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #9 of 9 (permalink) Old 05-26-2010, 07:40 PM
I think I've decided to not use PI, but I'll keep that in mind. Thanks
Why did they ever get rid of pilot injection? harry6.0 2003-2007 6.0L Power Stroke 3 05-01-2009 08:37 AM
Pilot Injection and Extreme Street Clevelandjim 2003-2007 6.0L Power Stroke 21 03-09-2006 01:01 PM
Fords Pilot injection thoughts PSDPlayer 2003-2007 6.0L Power Stroke 6 09-27-2005 12:43 AM
Pilot injection and split shot what is the difference? Carssuck 2003-2007 6.0L Power Stroke 4 09-14-2005 09:49 PM
Does Pilot Injection kill injectors? imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 7 09-07-2005 08:30 PM
