SCT and Smog? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by legend14, this thread has received 27 replies and been viewed 8677 times.
post #1 of 28 (permalink) Old 05-13-2010, 03:12 AM Thread Starter
SCT and Smog?
Can anyone help? I'm in California and had to smog my 2003 6.0 F250 diesel. Nightmare already! I have a 4" turbo back exhaust and custom tunes from Innovative. An economy tune, tow, and street tune for the past 2 years. Trucks been running great. I put truck back to stock,took it to smog place, the guy was friendly enough to pass the truck with no cat, but it would'nt pass because his machine could'nt COMMUNICATE WITH VEHICLE!! 8 times! So I took it to dealer to get checked, no problems, there laptop communicates with the truck PCM just fine. So I go back,same thing at smog place. I then take it to 2 other smog places and they too can't communicate with the truck PCM. Dealer even swapped PCM. So now I have to go to a Referee to get smog test and cleared, so I put the cat back on, a muffler guy did it.
My question is if I leave the cat on the 4" exhaust, will it affect how the truck runs when I run the tunes? Backpressure? Exhaust Temps? Dealer flashed truck with latest update, he said it had to do with the injectors. I read the strategy with the SCT tuner, and it did't change, same code, so no need to get new tunes I suppose. Just wondering if truck will run ok if I leave the cat on with tunes I got for a no cat exhaust? I have a piece I cant bolt in place of the cat also.
Thanks to all who can help!
legend14 is offline
post #2 of 28 (permalink) Old 05-13-2010, 11:11 PM
The Guy Mom Warned About
Fantom3993's Avatar
Send a message via AIM to Fantom3993
I don't think it will affect it too much. I'm running an SCT with a 4'' with cat and muffler.
John - 2004 Harley F250 Black/Competition Orange All the factory goodies, '05 Black Harley Headlights, Silverline 4'' Duals W/5'' Chrome Tips, Edge Platinum, Sirius Satellite,Pioneer AVIC D3
2001 Ford F550 XLT, Torreador Red,
7.3 Diesel, auto trans. chrome 19.5's
Rugby Dump Body, painted to match.
2004 F250 Reg Cab Long Box XL. Upgraded chrome grille and clear headlights from '04 Harley. Lariat Alloys and Factory CD/Cassette (Totaled 10/2/09)
1995 F350 Crew Cab Dually XLT, 460 Gas hog.
Fantom3993 is offline
post #3 of 28 (permalink) Old 05-13-2010, 11:22 PM Thread Starter
Fantom, what kind of tunes you running??
legend14 is offline
post #4 of 28 (permalink) Old 05-14-2010, 07:16 AM
Fantom3993's Avatar
I'm running Street and Tow from GOS racing. Currently I'm running the looney tune from vivian
post #5 of 28 (permalink) Old 05-15-2010, 01:21 AM Thread Starter
Whats your specs on the tunes? How much horse pwr, torque increase, all that stuff??
legend14 is offline
post #6 of 28 (permalink) Old 05-15-2010, 02:41 AM
Stuck in Commiefornia...
IdahoF350's Avatar
Tell the IDIOT smog tech to read the testing documentation. '03+ Ford Diesels use CAN protocol, and California currently can not communicate with it. He's not doing the test right.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #7 of 28 (permalink) Old 05-17-2010, 03:16 AM Thread Starter
Thanks Idaho! I took it to another tech a friend referred, and he said the same thing you did! It uses a can protacol whatever that is. The first 3 techs did'nt have anything written on their papers telling them that it was a can!! Anyhow, I put the cat back on, but not sure if I should leave it with my tunes, which are mild by the way. Can you tell me what the heck the muffler does on a straight pipe, I know stupid question. Does it just muffle the exhaust sound? Not for emissions right?
legend14 is offline
post #8 of 28 (permalink) Old 05-18-2010, 06:10 PM
IdahoF350's Avatar
For the purpose of passing the visual inspection you'll probably need the muffler. It doesn't have to really do much, just needs to be there. They aren't testing sound emissions and they probably won't ever. Actually, if they ever do, 6.0's are going to have a hard time passing total vehicle noise. Anyway, if you have a muffler, you probably ought to run it for the test if it's an easy install.
Something else to keep in mind, they are only testing opacity with a snap test, not chemical makeup of the exhaust, so as long as it doesn't huff a cloud when you snap the throttle, it doesn't matter if the cat is working or not, you'll still pass. I have a tow tune that would pass with flying colors, and it makes about 120ft/lbs more torque than stock. Just realize, No Smoke = No Problem!
post #9 of 28 (permalink) Old 05-18-2010, 09:05 PM
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
Per requirements the vehichle must retain all emissions equipment that also means the CAT, the CAT inspection should be nothing more than a visual.
AND YOU THOUGHT CARTER SUCKED
WasGas is offline
post #10 of 28 (permalink) Old 05-18-2010, 10:41 PM Thread Starter
AFTER the test though, should I leave the cat on , or bolt the straight piece back on that I made? Would it make much difference in the performance and temps on the truck??
legend14 is offline
Ca smog is almost here jdydiesel The Parking Lot 25 07-23-2010 04:52 AM
CA SMOG broth 2008-2010 6.4L Power Stroke 29 05-17-2010 04:59 PM
SMOG!!! IDImonsterstack 5.9L Cummins (1998.5-2002) 6 03-03-2010 02:38 AM
SCT and Smog Mustang42 2003-2007 6.0L Power Stroke 11 12-16-2005 10:13 PM
smog test ?? DieselDadio 1994-2003 7.3L Power Stroke 5 08-16-2005 04:13 PM
