pulling 8 dtc's?????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by swnrcng530, this thread has received 4 replies and been viewed 998 times.
post #1 of 5 (permalink) Old 05-16-2010, 12:16 AM Thread Starter
ok i was pulling my racecar trailer home earlier today and as i started to pick up speed before i started up the mountain wot, my programmer started flashing red. i checked when i got home and it had injector circ low 1-7 and one for ficm performance. wat is this and shouldnt it be throwing a check engine light?
05 f250 afe 3.5" to 4" exhaust no cat, green high performance air filter, accufab racing intake elbow, zoodad mod, edge evolution, ccv reroute, 2" lift with 315 70r17 hankook dynapro tires, banjo bolt mod, bb mod, removed fan shroud, swamps 48volt ficm
swnrcng530 is offline
post #2 of 5 (permalink) Old 05-16-2010, 04:16 AM
SLAPS President
teamroper60's Avatar
Images: 9
Your FICM is dying. It will eventually quit completely and the truck will shut off. You need to either repair it or replace it. The instructions for repairing it are on this site. Do a search on FICM repair and you can find them.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #3 of 5 (permalink) Old 05-16-2010, 08:31 PM
lilpooh's Avatar
Ifyour like me and not too skilled in circuit board repair, Swamps Diesels sells them refurbished with Heavy Duty parts. They cost about half of what the dealer will charge for a new, and if you buy a used one off e-bay you take a chance of buying a junk one. Also Swamp's come with a 1 year warranty.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #4 of 5 (permalink) Old 05-16-2010, 10:49 PM Thread Starter
thanks guys, just one more question? if i get one of swamps hot ficm's will the programmer i have work with it or will i have to get custom tuning?
post #5 of 5 (permalink) Old 05-16-2010, 11:03 PM
lilpooh's Avatar
I believe It will, But you will need to contact Swamp's just to make sure. Also Johnathan at swamps told me if you tow 10+K alot to get the 48v instead of the 58v. The excess load from towing could over heat the ficm. This is what he recommended. With my truck weighing in at 8240 lbs and towing a 7k 5th wheel, I got the 48v>
lilpooh is offline
swnrcng530 (05-17-2010)
Help with DTC's Micah2157 6.5L Diesel Engine 6 12-19-2009 05:48 AM
ALOT of DTC's stacks 2003-2007 6.0L Power Stroke 5 01-24-2009 04:42 PM
4 DTC's SSpeeDEMONSS 2003-2007 6.0L Power Stroke 1 07-08-2007 01:14 AM
Anyone check for DTC'S Rainman 2008-2010 6.4L Power Stroke 6 04-19-2007 03:25 AM
Need help with 3 DTC's 99fordtruckguy 1994-2003 7.3L Power Stroke 2 04-19-2007 01:11 AM
