Innovative tune speedo wrong - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KTMHauler, this thread has received 24 replies and been viewed 2606 times.
post #1 of 25 (permalink) Old 06-02-2010, 02:00 AM Thread Starter
Dirt biker
KTMHauler's Avatar
I got a SCT X3 3000 with 3 tunes Econo / Tow/ Street when i set wheel speed what on my van
it is 97in 6:00 to 6:00 so the closest number to set it at is 640 i have 3.55 gears when i tune to Street speedo is right on the money and Tow is right on
put it on Economy the speedo is 10mph to much when i am doing 70 speedo
is showing 90 but only on Economy tune
Things i say up here
KTMHauler is offline
post #2 of 25 (permalink) Old 06-02-2010, 04:08 AM
lilpooh's Avatar
That's weird! The revs per mile only commands the trans to shift at the proper rpm. It's not able to change your speedometer. Only the dealer has the ability to do that.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 25 (permalink) Old 06-02-2010, 05:11 AM Thread Starter
Dirt biker
KTMHauler's Avatar
The SCT X3 3000 can control tire size + - shift firmness +- any gear shift rpm +-
rear ratio top speed or low speed
just the rear rears and tire rev will affect speedo reading or the tune is wrong
if the street tune is right and the tow tune is right what do i tell econo the i have 140in wheel so it will come out right? I can e mail my econo tune back
to Innovative for them to look at it to see what is wrong with it
But how do i ask them They don't reply to email ? They must be on a long holiday
post #4 of 25 (permalink) Old 06-02-2010, 02:22 PM
lilpooh's Avatar
The SCT X-3 does not control tire size, Or speedometer. You are only using the tire rev per mile so that the trans will shift at the proper rpm range.
I have delt with Eric and Ted at ID, you must be patient, they will respond to your e-mail or phone call in the order that they get them.
lilpooh is offline
post #5 of 25 (permalink) Old 06-03-2010, 02:47 AM
********* and Mafia #90
Bcarriveau's Avatar
SCT will NOT and and in way can/will effect the speedo in your truck/van.
The Speedo is controlled the abs module witch is NOT programed or manipulated by the sct in any way.
Tire size setting is VERY imported to be set correctly for the Transmission tuning from the sct.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 25 (permalink) Old 06-03-2010, 06:49 AM Thread Starter
Dirt biker
KTMHauler's Avatar
I have a GPS that will tell the truth i have thursday off i got suspended for stress
post #7 of 25 (permalink) Old 06-03-2010, 07:28 AM
As others have said, SCT will not correct tire size. You enter it in the programmer to set shift points correctly, that is all. To calibrate the speedometer, you have to calibrate the ABS module for the correct tire size; this can be done at the dealership or with a tool like AutoEnginuity.
cartmanea is offline
post #8 of 25 (permalink) Old 06-03-2010, 08:25 PM Thread Starter
Dirt biker
KTMHauler's Avatar
I reloaded Econo tune today and i get the same thing and i used a Garmin
gps and with Econo tune it is 10 mph off speedo is 10mph faster and the transmissin shifts fast and hard
I unload back to stock and blaa stock is stock
Reload Street tune shifts good speedo is right
Tow is good too Right now i will reflash SCT tuner and reload it to Van
and see what changes
post #9 of 25 (permalink) Old 06-03-2010, 09:13 PM Thread Starter
Dirt biker
KTMHauler's Avatar
Sorry it is 10mph off on the Econo tune I don't care what anybody said
There is something in that tune that is doing that?
post #10 of 25 (permalink) Old 06-03-2010, 10:34 PM
Let it all Ride
Eazydeezy's Avatar
On that note, don't ask questions if you don't care what anybody says. These guys know what they're talking about. I guess you can say you have a magical SCT. Luck you!
Dominic
Eazydeezy is offline
Innovative race tune... lambstroker6.0 2003-2007 6.0L Power Stroke 19 12-24-2009 03:13 AM
just got my custom tune from innovative Hatchmaster 2003-2007 6.0 Tuner Forum 4 04-18-2007 03:31 PM
440 rwhp, Innovative tune! VegasSuperDuty 2003-2007 6.0 Tuner Forum 40 12-10-2006 07:55 PM
WOW!!! Innovative Xtreme Tune!!! Viper TT 2003-2007 6.0L Power Stroke 10 09-17-2005 05:00 AM
Innovative Street Tune?? jschall 2003-2007 6.0L Power Stroke 10 09-11-2005 03:55 AM
