icp sensor? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stroker99, this thread has received 2 replies and been viewed 1116 times.
post #1 of 3 (permalink) Old 06-15-2010, 03:41 AM Thread Starter
Angry icp sensor?
k so Iv'ecleaned the ipr changed orings on injectors and hpop under hard acceleration ses light comes on throwing a 1316 code havn't been able to get it scanned to figure out the rest of the codes Thought I would check the voltage on the icp one leg reads 5v the other 28-31v and 0 on the other weird thing is thats what I get from the plug plugged in or unplugged
99 psd 123000mi supechips programmer 4" magnaflow exausht.
Stroker99 is offline
post #2 of 3 (permalink) Old 06-16-2010, 04:38 AM
4cstr's Avatar
Images: 35
What setting do you have your superchips set on? If I were a betting man...your setting the SES light because your hpop can't keep up with the demand that the tuning is requiring of it.
On second thought...I believe the 1316 code has to deal with the IDM. I would check the harness and put some eyes on the module to see if there is some corrosion on the connector.
~Dave~
4cstr is offline
post #3 of 3 (permalink) Old 06-16-2010, 05:14 AM
1316 is the IDM. It means there are codes stored within the IDM itself, and you need a compatible diagnostic tool to retrieve those codes. The Superchips programmer cannot retrieve IDM codes.
Pocket is offline
icp sensor 1995nicholas 1994-2003 7.3L Power Stroke 4 05-27-2009 05:20 PM
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 02:54 AM
Cam sensor? '90 SSC Clone 1994-2003 7.3L Power Stroke 11 10-14-2007 09:51 PM
Cam Sensor? togoffrd Medium and Heavy Duty 9 05-26-2007 02:54 AM
MAP sensor ? racehauler 1994-2003 7.3L Power Stroke 15 02-20-2007 11:37 PM
