running rough when hot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by michael8840, this thread has received 8 replies and been viewed 2610 times.
post #1 of 9 (permalink) Old 06-17-2010, 12:46 AM Thread Starter
michael8840's Avatar
Question running rough when hot
Hi guys,
I changed the injectors of my 1999 F-250 to stage two and I also threw in a adrenaline hpop.
I shimmed the fpr till I got about 85 psi of fuel pressure just to make sure I got enough fuel to the injectors
I went for a road test and,but I noticed that when the engine is at operating temperature it seems to run rough
I ran it for about a week because I tought there was air in the system,when that didn't help I changed the cps and the ipr sensor with no change
What should I do next??
The truck is other than the injectors and the adrenaline hpop bone stock
Oh yes,I do have the 6637 air filter from napa
thanx guys,
michael
1996 7.3L powerstroke econoline E-350 cargo van
1999 7.3L superduty F-350 crew cab,lb
2003 6.0L powerstroke F-250 crew cab,sb FX4
2006 6.0L powerstroke F-250 crew cab,lb
1992 chevrolet caprice classic (305 cid
1998 mercury grand marquis LS
michael8840 is offline
post #2 of 9 (permalink) Old 06-17-2010, 03:35 AM
plainredtruck's Avatar
Images: 11
85 psi seems to be on the high side - 70-72 seems to be about the sweet spot, IIRC.
Did you change the tuning for the injectors?
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 9 (permalink) Old 06-17-2010, 11:35 AM Thread Starter
nope,no tuner
Do I need one to have this problem go away???
thanx,
michael
post #4 of 9 (permalink) Old 06-17-2010, 12:47 PM
Images: 11
Are your Stage 2 injectors single shots or split shots?
If they are singles, then you will see an improvement with the correct tuning.
Singles don't like to operate on split-shot tuning.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #5 of 9 (permalink) Old 06-17-2010, 01:59 PM Thread Starter
they are split shot injectors
thanx,
michael
post #6 of 9 (permalink) Old 06-18-2010, 02:17 AM
moose99psd's Avatar
deffinately back that fuel pressure down.. alot of pressure for no reason, also with the bigger amount of fuel from the injectors and no tuning it wont run properly even with splitshot injectors on a splitshot pcm. get a tuner on there and back the fuel pressure down to somewhere between 65-70. id also suggest guages if you dont have them.
moose99psd is offline
The Following User Says Thank You to moose99psd For this addition to TDG:
michael8840 (07-07-2010)
post #7 of 9 (permalink) Old 07-07-2010, 12:41 PM Thread Starter
Can you guys recommend me a tuner??? and keep in mind that I do not live in America
Thanx,
michael
post #8 of 9 (permalink) Old 07-07-2010, 11:44 PM
CSIPSD's Avatar
I would go with Power Hungry Performance and there FU package, they can email you tunes that you can install on your chip. If you dont like something they can tweak it and send it back...
Fuel pressure is way to high, anything from 60-70 is enough. More is not better, just causes fuel leaks and other issues.
Where did you get the injectors from? Poor idle when warm could be an injector issue.
CSIPSD is offline
The Following User Says Thank You to CSIPSD For this addition to TDG:
michael8840 (07-08-2010)
post #9 of 9 (permalink) Old 07-08-2010, 04:40 AM
Images: 11
There are a host of tuners available with the ability and know-how to deal with shipping internationally. The e-mail feature CSIPSD mentioned is a great feature and several vendors offer it.
I would suggest you take a look at the TDG vendors and post in our Vendor Forum to see who can meet your needs.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
The Following User Says Thank You to plainredtruck For this addition to TDG:
running rough droolinforparts 2003-2007 6.0L Power Stroke 27 08-29-2009 02:52 PM
running rough droolinforparts 2003-2007 6.0L Power Stroke 4 04-01-2008 02:21 AM
running rough taco_style 2003-2007 6.0L Power Stroke 19 11-15-2007 05:28 PM
Rough running 7.3??? Help???? Snowaholic 1994-2003 7.3L Power Stroke 3 09-06-2006 04:55 AM
12 v running rough Whitemare 5.9L Cummins 12 Valve (1994-1998.5) 5 09-24-2005 03:10 AM
