truck will have no reaction to acc. pedal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3rambaler, this thread has received 3 replies and been viewed 1610 times.
post #1 of 4 (permalink) Old 06-19-2010, 03:24 AM Thread Starter
7.3rambaler's Avatar
My truck just started doing this, if your just driving and let out of the pedal all the way and get back onto it it wont have any reaction...then i just put it in neutral and back in drive and it works...does it about 2 times a day. and sometimes feels like its giving half throttle of what im pushin on the pedal and other times its fine. only happens a little threwout the day
2000 F-250 7.3L. Ext Cab. Short Box.
Dp Tuner 80 eco-tune
Fully Built Tranny with Triple Disk Converter
AFE stage 2, 4in from turbo back stright pipe, foil Delete, X-Wheel Gauges-tranny-pryo-boost
7.3rambaler is offline
post #2 of 4 (permalink) Old 06-19-2010, 02:20 PM
The TPS is failing.
Traditionally you replace the throttle pedal assembly. However, some folks have found the TPS sensor itself and fixed it for less money. I'm not sure where to get the sensor, maybe someone can chime in on where to find one.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
7.3rambaler (06-19-2010)
post #3 of 4 (permalink) Old 06-20-2010, 02:57 AM
bpogue's Avatar
That does sound like the TPS. It is a simple changeout and a known problem. I paid $130 for the new pedal assembly from the dealer. They cannot sell just the sensor, and the whole assembly is actually made different than the original ones.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
The Following User Says Thank You to bpogue For this addition to TDG:
7.3rambaler (06-21-2010)
post #4 of 4 (permalink) Old 06-21-2010, 04:19 PM
BillsFan's Avatar
+1
I have had to repalce mine twice since I have had my truck.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
What's your reaction to this OASIS? FordTruckLover 2003-2007 6.0L Power Stroke 9 07-27-2009 11:22 PM
Ok almost lost the truck today, brake pedal to the floorboard Nomaprd 1994-2003 7.3L Power Stroke 9 02-14-2008 08:41 AM
Reaction From Troops about Kerry fordt The Parking Lot 10 11-05-2006 03:21 AM
Truck no Go When Pushing The Go Pedal Ramprat 1994-2003 7.3L Power Stroke 6 07-06-2006 12:36 AM
New Reaction Time Guage wideopen Drag Racing 1 10-27-2005 10:12 PM
