6.0 6 speed manual bolt to 7.3? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rademac, this thread has received 9 replies and been viewed 16345 times.
post #1 of 10 (permalink) Old 06-23-2010, 11:48 PM Thread Starter
I am wanting to do a conversion and looking for a tranny, just woundering if it would work.
rademac is offline
post #2 of 10 (permalink) Old 06-26-2010, 02:36 PM Thread Starter
any one?
rademac is offline
post #3 of 10 (permalink) Old 06-27-2010, 02:45 AM
balz out's Avatar
i would imagine that the trans is the same but everything else is different, they are both zf5 or zf6
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #4 of 10 (permalink) Old 07-01-2010, 04:53 AM
hayjayhorses's Avatar
the internals on the trans are the same, BUT bell housing on the 6.0 trans is smaller (same as V10 and 5.4 V8 gasser) then the 7.3 bell.
I bought a 4x4 6 speed out of 2003 V10 to convert my '01 7.3 F350 from 2wd to 4wd. I took both trannys and just swapped the cases it was not to bad, and it worked.
I even think the ratios on the ZF 6 speeds are the same gas or diesel I know on the ZF5 the ratios are much wider on the gasser tranny then the diesels
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #5 of 10 (permalink) Old 07-01-2010, 04:57 AM
No a 6.0 6sp is different than a 7.3 my boss has a 6.0 and when it went out he found alot of 7.3 trans, but they wouldn't work. I believe the bolt pattern is different and I know for a fact that the input shaft on a 6.0 is way bigger. Don't let a trans place tell you it will bolt in that's what they did with him and he had a hard time taking it back, I hope this helps.
99 f-350 cc duallie 7.3l powerstroke 6sp 4x4
Finally on the road but needing lots of little problems fixed, injectors are in the works once the economy gets better
94 f-350 CC long bed idi-t
mods :k&n filter, hypermax 3.5" exhaust, injectors, pyro & boost gauges, a zf5 swap , IP , rebuilt turbo
future mods: An engine rebuild, custom intercooler & hydrogen (HHO) generator
Singles club member #238
710_burner is offline
post #6 of 10 (permalink) Old 07-01-2010, 11:36 PM
balz out's Avatar
bolt pattern on bell housing or trans itself? couldnt you swap out the shaft?
balz out is offline
post #7 of 10 (permalink) Old 07-02-2010, 05:13 AM
The bolt pattern on the 6.0 trans is smaller then the 7.3.
Are you switching from an auto?
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #8 of 10 (permalink) Old 07-12-2010, 05:07 AM
Don't quote me on this, but I think the only thing that you are going to need that is different is the flywheel. I have a +05 zf6 in my truck from Midwest Transmissions. The case bolted right up without a problem. You might contact Midwest to see what they have to say. They are quality folk and diesel nuts to boot.
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
post #9 of 10 (permalink) Old 07-12-2010, 05:39 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
I have an extra 6 speed tranny out of an 05 with 40+K ...PM me if you are interested.
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #10 of 10 (permalink) Old 07-14-2010, 12:43 PM
Images: 9
No it will not bolt up. The bolt pattern is way different. Caleb you have the 05 up 6.0L guts in your transmission that we built for you. The internals are way better. If you have any questions pm me or give me a call at my shop 888-824-2012.
Dan
SoGrand is offline
Dmax with 6 speed manual southern-stroke Duramax 2001-2004 (LB7) 3 05-17-2010 11:48 PM
switching from a manual 5 speed to a manual 6 speed BEHR2010 1994-2003 7.3L Power Stroke 13 04-25-2009 04:27 PM
zf6 speed manual whitediesel23 Whats Been Sold 3 02-23-2008 06:14 AM
SCT needs a 6-speed manual SouthTexasDiese 2008-2010 6.4L Engine Tuner Forum 0 09-19-2007 10:45 PM
anyone driven a 6 speed manual yet? KERR 2008-2010 6.4L Power Stroke 66 03-07-2007 09:28 PM
