SERVICE CODE P-284? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BEERTHIRDY, this thread has received 2 replies and been viewed 1567 times.
post #1 of 3 (permalink) Old 06-24-2010, 02:46 AM Thread Starter
SERVICE CODE P-284?
1999 F-350. RUNNING ROUGH WITH ALOT OF WHITE SMOKE. SCANNER BRINGS UP P-284 #8 CYLINDER CONTRIBUTION/FAULT. INJECTOR PASSED BUZZ TEST BUT I REPLACED IT ANYWAY. STILL HAVE SAME PROBLEM, WHERE DO I GO FROM HERE???
BEERTHIRDY is offline
post #2 of 3 (permalink) Old 06-24-2010, 06:35 AM
4play's Avatar
Not to question your intelligence but you sure you did #8, rear cyl on LH/drivers side.
P0284
Possible causes:
broken compression rings
inoperative injector assembly
leaking or bent valves
bent push rod
broken rocker arm bolts
bent connecting rod
4play is offline
post #3 of 3 (permalink) Old 06-24-2010, 11:28 AM Thread Starter
YES, I DID CHANGE #8 INJECTOR. DRIVER'S SIDE REAR INJECTOR. THE OLD OLD LOOKED GOOD, SEALS AND COPPER WASHER WERE STILL IN GOOD SHAPE.
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 03:29 AM
"Service Engine Soon" and fault code ArmyAviator Duramax 2001-2004 (LB7) 6 08-01-2009 05:17 PM
code scanner, F-350 ford service engine light Granny53 1994-2003 7.3L Power Stroke 10 03-13-2009 07:05 PM
SEVERE SERVICE service? kenkillsr 2003-2007 6.0L Power Stroke 5 08-19-2007 06:06 AM
Cummins 6.7 L Service Bulliten "Re-Flash" SERVICE BULLETIN 18-033-07 REV.A Myguy 6.7L Cummins (2007.5-2011) 5 07-23-2007 03:00 AM
