popping noise? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sdz, this thread has received 3 replies and been viewed 1192 times.
post #1 of 4 (permalink) Old 06-24-2010, 09:17 PM Thread Starter
sdz
popping noise?
anyone know what or where that popping noise is coming from when I drive my supercab on uneven terrain?sounds like its coming from the drivers side front fender or frame mount?
Thanks
sdz is offline
post #2 of 4 (permalink) Old 06-24-2010, 10:42 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
If you are driving an OBS (Old body style) there is a rivet in the front end drives side frame rail that works its way loose. You can either smash it again or grind it off and replace it with a bolt. It has been years since I have seen it or worked on one so I can't pinpoint which one it is... Sorry!
Hope this helps.
TooLoudTooBad is offline
post #3 of 4 (permalink) Old 06-30-2010, 02:18 PM
BillsFan's Avatar
What truck?
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #4 of 4 (permalink) Old 06-30-2010, 02:48 PM
Cratos's Avatar
mine was spring bushings gone in the front.
2012 f-240 lbsc 4x4
Cratos is offline
2008 making a popping noise under truck steve snider 2008-2010 6.4L Engine Tuner Forum 1 03-03-2010 01:26 AM
Popping noise in the front end gator_boy_77 2003-2007 6.0L Power Stroke 4 03-02-2010 04:43 PM
Popping noise from rear end? Jakkle5 General Ford Truck and Excursion 2 04-05-2008 02:20 AM
Popping noise when I hit the brakes WBV06CTD 5.9L Cummins (1998.5-2002) 2 06-10-2007 04:02 AM
Bad popping noise......?? BigWhiteSicksO 2003-2007 6.0L Power Stroke 14 10-07-2005 06:46 AM
