No Start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Strokerin, this thread has received 8 replies and been viewed 1556 times.
post #1 of 9 (permalink) Old 06-25-2010, 02:13 AM Thread Starter
No Start
My truck quit on me. Shut it off and now it won't restart. Has new batteries, starter, alternator and the fuel bowl heater is unplugged. I'm wondering if it is the IPR. I'm still waiting for the engine to cool so I can try it again. Any thoughts?
1996 F250, 219K miles, manual tranny. Beans Diesel Stage 1 injectors, 5 position chip, homemade intake, 5 in. straight pipe exhaust.
Strokerin is offline
post #2 of 9 (permalink) Old 06-25-2010, 03:18 AM
bpogue's Avatar
More information needed.
Is it cranking? Do you have the wait to start light? If it cranks, is there any smoke?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 9 (permalink) Old 06-25-2010, 10:36 AM Thread Starter
It cranks like crazy. No smoke. Have a wait to start light. All fuses check out good. I tried to start it again last night and it was a no go. The engine wasn't cold, but I could touch everything with a bare hand and it was just a warm. I don't know how cool it has to be before it would start if it was an IPR problem. It was running great just like normal when I shut it off. Nothing irregular had happened in the hour drive home that would suggest that there was a problem.
post #4 of 9 (permalink) Old 06-25-2010, 11:30 AM
plainredtruck's Avatar
Images: 11
Are you getting fuel at all?
If you have a spare CPS, throw that in there. Check the UVC harnesses while you're at it.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #5 of 9 (permalink) Old 06-27-2010, 09:07 AM Thread Starter
If it was the CPS, wouldn't it have run rough before I shut it down? I'm thinking that I'm not getting fuel. I'll pick up a spare CPS tomorrow. The one that is on it is new, but that doesn't mean anything. UVC harness looks good. I've read about the IDM going bad on these, is that a common problem?
post #6 of 9 (permalink) Old 06-28-2010, 02:12 AM Thread Starter
So as a last ditch effort, I used ether. Fired right up. Anybody know what the fuel pressure should be at the Shrader valve while cranking?
post #7 of 9 (permalink) Old 06-28-2010, 03:50 AM
Images: 11
50-72psi - I'm not certain it will run with less than 35, but that's just a # that sticks in my brain for some reason.
Open the drain on the fuel bowl and see if you're getting any fuel flowing out.
Turn the key on and see if any flows then as well.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #8 of 9 (permalink) Old 06-28-2010, 09:10 AM Thread Starter
The fuel bowl and HPOP reservoir were full when I checked before the ether. I'll drain the bowl and check the pressure on the fuel. I hate it when stuff doesn't work!
post #9 of 9 (permalink) Old 07-16-2010, 03:14 AM Thread Starter
Bad o-rings on an injector. It was letting oil bleed back and wouldn't hold enough pressure to fire the injectors. So, new o-rings and I should be good to go.
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
Fresh Start: needing advice to start off on the right foot. MoparChallenger 5.9L Cummins (2003-2007.5) 22 03-07-2008 02:10 AM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 12:55 PM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
