new to me 2000 f350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firedude26, this thread has received 9 replies and been viewed 1923 times.
post #1 of 10 (permalink) Old 06-25-2010, 11:59 PM Thread Starter
new to me 2000 f350
ok im replacing my 99 250 with a 2000 350 with 67000 miles, im looking at new 4" exhausts, summit has a couple at a fair price. is there something i should be looking for? i calleda few exhaust places around here and noone can give me a price on building me a exhaust, the going rate to install my exhaust is 100 bucks. unless someone knows of someone in the downriver area of michigan?
aslo im gonna put a air intake on it any suggestions for this???
i havea bullydog flip chip im gonna install once i make sure it is compatable with the 2000, if not im sending back for a tune up.
thanks
firedude26 is offline
post #2 of 10 (permalink) Old 06-26-2010, 06:47 AM
It's not too bad to change out that turbo back exhaust. It took me about two hours.
2000 F250 Supercab 2wd, 6spd, DP Tuner, Southbend conFE, MBRP 4" turbo back straight pipe. DIY intake.
JoeDirte is offline
post #3 of 10 (permalink) Old 06-26-2010, 07:29 AM
4cstr's Avatar
Images: 35
As was mentioned...the exhaust isn't that hard to install. A nice afternoon task.
Personally...I would ditch that flip-chip and go with a custom burnt chip built for the code of truck.
As for an intake...lots of possibilities. You could go with a Tymar/DIY intake...which filters great and is the cheapest of the bunch. I have an aFe and like it. S&B also has a good system. Avoid k&n...especially their flat panel filters.
~Dave~
4cstr is offline
post #4 of 10 (permalink) Old 06-27-2010, 07:05 AM
moose99psd's Avatar
thier fipk kits are fine. there no worse or better than any of the oil filters.. the "stock" style k+n's arent made well and do not fit the box correctly.. as far as the chip, is the old truck an auto or std and the new truck? if they are both the same the chip will work in either truck. the exhausts there not that much too them, the biggest thing about them is wether they fit well and if the hangers are in the correct spots as to not cause any issues during instalation. i have a magnaflow exhaust and it was made with some very good quality. if you have a shop do it for you make sure that they bend over mandrel and not any other way.
moose99psd is offline
The Following User Says Thank You to moose99psd For this addition to TDG:
firedude26 (06-27-2010)
post #5 of 10 (permalink) Old 06-30-2010, 02:16 PM
BillsFan's Avatar
The exhaust is easy to do, but $100 isn't bad if you don't have the tools/time.
There are a lot of options out there you just have to read up, do some research and see what's in your budget.
Congrats on the new truck!
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #6 of 10 (permalink) Old 06-30-2010, 03:12 PM Thread Starter
well so far i ordered a summit 4" exhaust kit and a air intake DYI. i do wanna put gauges on it and im waiting for bullydog to answer my email about using the 6 pos from my 99 on the 2000. wheres a good place to find gauges? what is needed in a guage setup? are they easy to install?
post #7 of 10 (permalink) Old 07-02-2010, 03:52 AM Thread Starter
got exhaust going to have it done tomm am, bullydog is gonna redo my 6 pos to work on my 2000 free of charge, now i need info on how to do gauges
post #8 of 10 (permalink) Old 07-02-2010, 03:57 AM
plainredtruck's Avatar
Images: 11
check with the TDG Vendors and see if what they offer.
You probably want boost, EGT & transmission temps as a minimum.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #9 of 10 (permalink) Old 07-03-2010, 03:05 AM
balz out's Avatar
www.dieselmanor.com has a good write up on installing gauges
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #10 of 10 (permalink) Old 07-08-2010, 05:11 AM
4cstr's Avatar
Images: 35
So do we. gauge install
~Dave~
4cstr is offline
Lookin at buying a 2000 F350 gr33ng0bl1n 1994-2003 7.3L Power Stroke 2 08-12-2009 02:46 PM
2000 F350 Crew cab sb D-Man Whats Been Sold 0 06-27-2009 03:46 PM
2000 f350 whitediesel23 Ford Oasis requests 1 01-27-2008 02:13 AM
2000 f350 7.3l MrJman General Ford Truck and Excursion 1 08-11-2007 01:03 AM
2000 F350 Stacks ELKHUNTR Supporting Vendors Forum 2 07-14-2007 11:03 AM
