Holy Valve Cover Gaskets! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JoeDirte, this thread has received 10 replies and been viewed 3136 times.
post #1 of 11 (permalink) Old 06-28-2010, 01:26 AM Thread Starter
I thought I was going to pop that valve cover to check on the uvch today. I stopped by the local parts store to discover the gaskets are made of gold...$104 for FelPro (one side). I checked Rock Auto online and it's a measly $62 plus shipping. How lucky have you guys been to remove the valve cover without destroying the gasket? I'm going to trying and reuse the old one. Either that or I will use RTV or gorilla snot. Does anyone have torque specs on the valve cover? I'm guessing 25-30 in lbs.
2000 F250 Supercab 2wd, 6spd, DP Tuner, Southbend conFE, MBRP 4" turbo back straight pipe. DIY intake.
JoeDirte is offline
post #2 of 11 (permalink) Old 06-28-2010, 04:17 AM
bpogue's Avatar
I've had mine off a few times without incident. They are usually pretty tough. I guess they have to be with all that wiring part of them.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 11 (permalink) Old 06-28-2010, 04:50 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
you shouldn't need gaskets unless there is a wiring problem and it melted part of it or else you are really rough and break one of them
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 11 (permalink) Old 06-28-2010, 08:18 AM Thread Starter
well maybe I do need one then. I took a better look at the gasket and realize that the wiring goes through that. Maybe I'll take that off and check the ohms going through the gasket. Where can I get the UVCH?
JoeDirte is offline
post #5 of 11 (permalink) Old 06-29-2010, 04:02 AM
bpogue's Avatar
So why are you replacing them? Do you have a leak somewhere? I know you can get them at the dealer, maybe other places. While you have the valve covers off, you should probably but the uvc wedges in to keep the connections from coming apart in the future.
2003 Takeuchi TL150
bpogue is offline
post #6 of 11 (permalink) Old 06-30-2010, 02:09 AM Thread Starter
No leaks. I got codes that say all my glow plugs have a problem on one side. I figure that's a fat chance and that the uvch came loose. I didn't want to pull the cover just to find out the connector on the gasket is bad and I figured I'd change the uvch. I'll wait until the glow plugs actually die before switching those out.
JoeDirte is offline
post #7 of 11 (permalink) Old 06-30-2010, 07:05 AM
Pull the valve covers off. The valve cover gaskets are reusable, so you can pop off the valve cover, plug the wiring back in, and put it all back together without issue.
I'm guessing that since you came up with glow plug codes, your truck is a Cali model?
Pocket is offline
post #8 of 11 (permalink) Old 06-30-2010, 09:17 AM Thread Starter
Yep. California truck.
JoeDirte is offline
post #9 of 11 (permalink) Old 07-12-2010, 05:43 AM Thread Starter
Okay. So that didn't work. I changed out the gasket and the uvch and I still get the same codes. I saw on the sticky of where the GPR is located. My question is why would only one bank of gp's have a problem. If the GPR is funky, wouldn't both banks be down? There's only one GPR, correct?
JoeDirte is offline
post #10 of 11 (permalink) Old 07-12-2010, 12:15 PM
balz out's Avatar
yes there is only one. maybe by chance if your not the original owner and for some reason they only swapped out four of the eight g.ps and now the other four are going bad? did u check that all the plugs were connected correctly?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
Valve cover gaskets? turboculosis 5.9L Cummins 12 Valve (1994-1998.5) 6 01-25-2009 01:53 AM
LB7 Valve Cover Gaskets ripmf666 Whats Been Sold 0 12-25-2008 10:21 AM
Valve Cover Gaskets!?!?!?! PRICE? indyF-350psd 1994-2003 7.3L Power Stroke 12 04-07-2008 01:41 AM
Leaking valve cover gaskets. fishon 5.9L Cummins 12 Valve (1994-1998.5) 11 12-01-2007 07:47 PM
Valve cover gaskets...?? TireFryerSS 5.9L Cummins 12 Valve (1994-1998.5) 11 03-04-2007 09:59 PM
