no boost = blown turbo?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by amd_h4x0r, this thread has received 5 replies and been viewed 3441 times.
post #1 of 6 (permalink) Old 06-29-2010, 03:38 AM Thread Starter
amd_h4x0r's Avatar
I was really getting into it to see what it would do (boost was around 20psi or so) then all of a sudden something popped, a bunch of air released (pshhhh!), and turbo boost went to zero.
I think I might have popped a line or popped a connection loose. I checked the boost gauge line and it is fine, so it's not leaking through that. I'm hoping it's just a blown/loose line. The turbo didn't make any noises when it happened, it just doesn't spool up now.
I need some suggestions on where to start looking.
2002 F-250 7.3 XLT CC/SB -- 4R100 -- 3.73 gears -- 139k miles -- 285/75R16 TreadWright Guard Dog M/Ts -- 3" leveling kit
4" MBRP exhaust -- foil delete -- DIY intake -- zoodad mod -- Wicked Wheel -- Auto Meter Ultra-Lite II gauges -- PHP F.U. 6 position chip
amd_h4x0r is offline
post #2 of 6 (permalink) Old 06-29-2010, 03:47 AM
bpogue's Avatar
It could be the turbo, but is more likely an intercooler boot. They are usually the weak point in the system. Check all of them. Sometimes leaks are difficult to find by looking from the top side. You may have to remove them, unless you can come up with some way to put a little air in the system and listen for leaks.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 6 (permalink) Old 06-29-2010, 05:14 AM
moose99psd's Avatar
the constant clamp things SUCK! deffinately want to replace those.. look for the tubes being blown out of the boots. if you have a split boot then id replace all of them from either a vendor or possibly a big rig shop and cut your own.
moose99psd is offline
post #4 of 6 (permalink) Old 06-29-2010, 11:30 AM
brendonv's Avatar
I almost poo'd myself when this first happen to me. Coming up a steep grade, towing a chipper with a load of wood chips in the back. POP, pulled into a parking lot and put the boot back on. I ended up cleaning them all, and putting them back on, good ever since. Some people recommend putting them back on with hair spray, as it has that sticky film.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #5 of 6 (permalink) Old 06-29-2010, 04:35 PM Thread Starter
amd_h4x0r's Avatar
Thanks for the quick responses. Turns out it was an intercooler connection. I guess I didn't tighten the clamps enough when I put it back on after doing my foil-delete. I just didn't notice it last night in the dark.
post #6 of 6 (permalink) Old 07-01-2010, 01:23 AM
moose99psd's Avatar
yea the hairspray works wonders.. and making sure that the boots are nice and clean on the inside and not oily is key as well. dont be surprised if it pops again.. seems once they pop it tends to happen more often.
Blown turbo or.....? Eazydeezy 2003-2007 6.0L Power Stroke 11 05-14-2009 11:02 PM
boost=blown hg? RHCDIESEL 2003-2007 6.0L Power Stroke 9 01-13-2008 05:52 AM
Blown Turbo bailey47 2008-2010 6.4L Power Stroke 12 11-21-2007 07:52 PM
Blown Turbo on My 05' videokorn 5.9L Cummins (2003-2007.5) 6 08-28-2007 06:15 PM
Blown Turbo? Team Cold Beer 2003-2007 6.0L Power Stroke 13 05-13-2006 11:55 PM
