ebpv surge? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by joeseppy, this thread has received 11 replies and been viewed 3850 times.
post #1 of 12 (permalink) Old 06-30-2010, 05:00 PM Thread Starter
ebpv surge?
just got my truck back from the dealer they had the motor out and resealed my oilpan and replaced my manifolds and the uppipes to the turbo, anyways noticed yesterday moringn on cold startup, when the ebpv kicks in, it surges. before it used to make a rushing/hising noise steady till it either warmed up or you hit the brake pedal. now it does it in surges,, like hard to describe, but it comes on and off every 2 seconds or so, like shhh, pause, shhhh, pause , shhh pause, any ideas what is going on to cuase this? could it be something they did?
2002 f350 crew short,sct tuner(tunes by tad)econo , tow , and max power, afe stage 2 intake, mbrp 4 inch exhaust,285/75/16bfg at's,remote start,guages,2006 grill/harley headlamps,foil delete
joeseppy is offline
post #2 of 12 (permalink) Old 06-30-2010, 06:32 PM
plainredtruck's Avatar
Images: 11
It could be that the sensor is going bad or the wires are screwed up or the tube is plugged.
Do you really use the EBPV that much where you are?
It's worth gutting if you don't need it.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 12 (permalink) Old 06-30-2010, 07:27 PM Thread Starter
is the sensor mounted on the end of the tube that comes out of the rh front exhuast manifold?, i priced the sensor at ford it's $200.00! they put new manifolds on my truck and had the tube off so i think they would of cleaned the tube . if it was dirty, didn't do this before it went into the shop. maybe a bad sensor???? is it the one i am looking at?
joeseppy is offline
post #4 of 12 (permalink) Old 06-30-2010, 07:38 PM
Images: 11
Try this:
Unplug the thing tonight and see if it does it to you tomorrow morning.
Look here:
https://www.thedieselgarage.com/forum...ad.php?t=59957
If it doesn't, then there's your problem.
If you don't need it, get yourself a set of pedestal o-rings and delete the whole thing.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #5 of 12 (permalink) Old 06-30-2010, 08:22 PM
Images: 11
Pg 33 of the document found @ http://www.forddoctorsdts.com/articl...icle-06-08.php
It's listed as the "98-99.5 7.3 DIT Direct Injection Turbocharged Diesel" on that page and it's 39MB - via one of the 7.3L Sticky Archive posts - shows the sensor as being relocated to the front of the HPOP oil reservoir.
That document is a nice one to keep handy for future use with your truck.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #6 of 12 (permalink) Old 06-30-2010, 10:21 PM Thread Starter
so if i unplug it , will the ebpv come on in the morn? is it possible to clean the sensor, looks like the used silicone on my ,manifolds, wonder if a peice could of blocked the sensor or something..i dunno about deleting it, it gerts pretty cold here in the winter and i don't think the truck would warm up without it... can get to -25c without the windchill...
joeseppy is offline
post #7 of 12 (permalink) Old 07-01-2010, 04:34 AM
Images: 11
RTV on your exhaust manifolds??????
Better be very high temp stuff
You should be plugging it in at those temps anyways, but if it's unplugged it should not come on. If it does, you have a mechanical malfunction and will need to get it serviced/replaced.
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #8 of 12 (permalink) Old 07-01-2010, 01:24 PM
Mod Friendly Title
Zaairman's Avatar
Your truck will warm up just as fast without the EBPV.... just won't make that annoying sound.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #9 of 12 (permalink) Old 07-02-2010, 03:50 AM
take it back and tell them that it didnt do it before, and see if they will fix it?
firedude26 is offline
post #10 of 12 (permalink) Old 07-02-2010, 07:27 AM Thread Starter
ya i am taking it back saturday, but what they said is if it is not something they did , they don't know if the warranty will cover it until they know what is wrong so i may have to pay..
what i noticed today is it was not cold out this morn, started truck, everything normal for the first 2 minutes approx, then after about a minute of the hissing, which is normal it starts to cycle/surge, could this be it trying to come off of the ebpv ??? usually in the winter it will sit on the ebpv till i get in it and hit the brake.. but maybe it is too warm and it wants to pull off but can't or is it normal, anyone out there confirm this?
joeseppy is offline
EBPV Mod lucasd 1994-2003 7.3L Power Stroke 6 02-18-2009 01:10 AM
ebpv Lucas 1994-2003 7.3L Power Stroke 8 04-08-2008 01:45 AM
Ebpv ? stroker_baldy 1994-2003 7.3L Power Stroke 10 10-20-2007 02:09 AM
ebpv? puredieselpower 1994-2003 7.3L Power Stroke 11 11-28-2006 11:56 PM
New ebpv? bigs rig 1994-2003 7.3L Power Stroke 3 02-07-2006 09:50 PM
