injector nozzle question? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by balz out, this thread has received 12 replies and been viewed 5122 times.
post #1 of 13 (permalink) Old 07-03-2010, 03:14 AM Thread Starter
balz out's Avatar
so this week iam going to be picking up my stage ones from fairview diesel, guy is about 5 minutes from the job iam running right now and from what i hear he really knows his ****, 1200 for the injectors and he says iam going to be very pleased he flow tested them and said they are exactly what i asked for, my question is- im now thinking about nozzles, can i take them off and have a machine shop drill them to make them bigger and if i can what size should they be drilled out too?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #2 of 13 (permalink) Old 07-03-2010, 04:11 AM
plainredtruck's Avatar
Images: 11
I can't imagine trusting a machine shop to do injector nozzles.
And I wouldn't let anyone drill them.
I think I would only mod brand new nozzles to start with and not with just any old EDM guy, either.
What is it you want to accomplish with these injectors?
Converting standard AC's (Stage 1's) to "Stage 2's" is a nozzle upgrade for most builders.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 13 (permalink) Old 07-03-2010, 02:32 PM Thread Starter
balz out's Avatar
i was just curious if it could be done so if down the road i want to convert the stage ones to twos i could i guess it would just be cheaper to buy new nozzles huh?
balz out is offline
post #4 of 13 (permalink) Old 07-04-2010, 03:25 PM
You don't just "remove the nozzles."
The entire injector needs to be dis-assembled to get to the nozzle.
And it's way cheaper to just replace them with new larger nozzles than to enlarge the holes in yours.
Yes, they can be drilled, but only by a facility that specializes in it. Drilling would be 3rd choice of process to enlarge them: 1) EDM, 2) EH, 3) Drill.
DZLJIM is offline
post #5 of 13 (permalink) Old 07-04-2010, 05:37 PM Thread Starter
balz out's Avatar
thanks for the advise fellas!!!
balz out is offline
post #6 of 13 (permalink) Old 07-07-2010, 06:00 AM
CSIPSD's Avatar
Do yourself a favor... Find out EXACTLY what your injectors flow, or you dont know crap...
CSIPSD is offline
post #7 of 13 (permalink) Old 07-08-2010, 12:24 AM Thread Starter
balz out's Avatar
i picked up the injectors yesterday, this guys shop was nothing but 7.3 injectors, he flowed them and they were right under 160 he gave me the print out and he said it is about 20% increase i beleive. he even told me if i wasnt happy with them to pull them and he would go where ever i wanted and pay for the injectors himself, i had injectors in my obs from him and they were awsome
balz out is offline
post #8 of 13 (permalink) Old 07-08-2010, 01:32 AM
CSIPSD's Avatar
Are they single shots, split shots, stock nozzles, 30%, 80%, 100%, 200% nozzles... You need to know these things in order for your tuner to properly tune your truck.
CSIPSD is offline
post #9 of 13 (permalink) Old 07-08-2010, 01:37 AM Thread Starter
balz out's Avatar
split shot. stock nozzles, bigger intensifier piston, i think he said something about a different solenoid also, and i forget i have the receipt in my truck
balz out is offline
post #10 of 13 (permalink) Old 07-08-2010, 01:43 AM
CSIPSD's Avatar
If he changed the solenoid he did it because one was bad, there is no performance part of the solenoid.
Split shot 160 is going to suck for HPO usage, better start looking for a AD from Dieselsite.
Stock nozzle means lots of PW to empty the injector to get a full 160cc out of them.
Sounds like all he did was machine the pistons, which is fine, and should give you a nice 30-40hp boost.
CSIPSD is offline
jammer nozzle question OFFRODEN 5.9L Cummins (1998.5-2002) 3 05-16-2009 01:14 PM
2003 6.0, stock, with cracked injector nozzle?? Klutch 2003-2007 6.0L Power Stroke 2 05-06-2009 04:28 PM
LB7 Fuel Injector Nozzle Tube Sleeve Replacement ripmf666 GM Spec Info 0 12-28-2008 10:30 AM
2nd Gen 24 Valve Injector Nozzle Swap wobblewagon Dodge - Modification instructions, Product installs and Tech Articles 2 03-27-2008 05:50 PM
2001 injector nozzle swap out??????? wobblewagon 5.9L Cummins (1998.5-2002) 20 03-07-2006 07:26 PM
