02 F350 7.3 turbo using oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sfdsford, this thread has received 1 replies and been viewed 1795 times.
post #1 of 2 (permalink) Old 07-11-2010, 03:16 AM Thread Starter
I have an 02 F350 Super Duty. There are no mods on it. I bought it from a guy and he told me it ran great and then I went to start it one day and it kept stalling on me. Soon to find out it was out of oil. It was going through 3 qt a day easily somtimes more. So I had a "powerstroke" man change the outter o'rings on the injectors and said that would fix it. It did not and it is still using excessive oil. I took it back to the guy and he said that there are o'rings on the inside of the injectors and I need to buy new injectors to fix that for $1,200. There are no puddles when it sits. Doesn't white smoke at all. And the undercarriage is spotless. Any ideas?
sfdsford is offline
post #2 of 2 (permalink) Old 07-11-2010, 05:40 AM
Sad to say, the mechanic is probably right. Mine did the same thing awhile ago and I replaced the outer o-rings. That fixed it for a little while and then the injectors themselves go to the point they were passing oil so I had to replace them. $1200 sounds pretty close to the best you might find too.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
2005 F350 with 6.0l turbo problems FTAJ 2003-2007 6.0L Power Stroke 8 05-04-2010 02:15 PM
2005 F350 with 6.0l turbo FTAJ 2003-2007 6.0L Power Stroke 0 05-02-2010 05:13 PM
CA FS: 92 F350 Turbo parts. justs13r Whats Been Sold 0 03-31-2008 07:16 AM
will a 7.3L idi turbo swap into 1997 (early) f350 5 speed 4x4 kenji 7.3L and 6.9 IDI (Pre 1994) 14 06-29-2007 01:24 AM
E350 psd turbo vs F350 psd turbo ichthus 2003-2007 6.0L Power Stroke 5 06-08-2007 05:15 AM
