wicked wheel question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by balz out, this thread has received 2 replies and been viewed 1241 times.
post #1 of 3 (permalink) Old 07-11-2010, 04:52 PM Thread Starter
balz out's Avatar
so i baught a wicked wheel a long time back never got around to putting it on so when i did my injectors i said hey wtf do it now since everything is out of the way, well the bolts that hold it to the pedistal are tighter than a nuns crotch and they are not coming off, soaked them for days in penetrating oil and it did nothing, my question is can it be changed out with out taking the turbo off and if so how do i go about doing it?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #2 of 3 (permalink) Old 07-11-2010, 06:02 PM
Paul Ray's Avatar
you will have to remove the valve cover. use a 1/2" impact and spin the old wheel off with a few short burst of the impact. and just use a few hits from the impact to install the new one. not a hard job. there is a video of it on you tube that shows it step by step
Paul Ray is offline
post #3 of 3 (permalink) Old 07-12-2010, 01:15 AM Thread Starter
balz out's Avatar
did you have to remove the valve cover?
balz out is offline
wicked wheel dondiesel444 Supporting Vendors Forum 1 06-28-2010 11:22 AM
Need a Wicked Wheel... Zaairman Supporting Vendors Forum 3 03-09-2009 01:31 PM
Wicked wheel? King0581 1994-2003 7.3L Power Stroke 1 03-30-2008 09:47 PM
Wicked Wheel ? erikfowl 2003-2007 6.0L Power Stroke 3 12-27-2007 11:58 PM
wicked wheel question on a early 99 jebsurf 1994-2003 7.3L Power Stroke 9 04-07-2007 03:24 AM
