clogged return fuel line ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RussK, this thread has received 1 replies and been viewed 6081 times.
post #1 of 2 (permalink) Old 07-12-2010, 06:06 PM Thread Starter
RussK's Avatar
I was told that a clogged return fuel line to the tank can cause low power.
It says that a restricted orifice or clogged strainer screen in the filter housing assembly
is this possible on a 7.3?
This info is from a scanner and its kinda vague on which years it refers to.
Thanks
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #2 of 2 (permalink) Old 07-16-2010, 05:20 AM
pontiacross's Avatar
I have never heard of a clogged return line causing problems on a 7.3 but I guess it is possible.
I have seen plugged inlet screens on the OBS filter housing inlets and I have heard of the screen in the tank plugging up before.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
Question - Return Line on Fuel Bowl Seafordguy 1994-2003 7.3L Power Stroke 2 04-29-2010 01:18 AM
fuel return line john_k_45 5.9L Cummins 12 Valve (1994-1998.5) 7 09-23-2009 12:24 AM
fuel return line stillcrazyinlaw 5.9L Cummins 12 Valve (1994-1998.5) 1 02-25-2008 09:48 PM
fuel return line? f_stahl 1994-2003 7.3L Power Stroke 3 02-08-2007 01:28 AM
return line on fuel housing doob51 5.9L Cummins 12 Valve (1994-1998.5) 1 01-14-2007 08:07 AM
