Warning light thresholds... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CSIPSD, this thread has received 9 replies and been viewed 2196 times.
post #1 of 10 (permalink) Old 07-12-2010, 11:01 PM Thread Starter
CSIPSD's Avatar
Tell me where you would like to see a "warning" light on a gauge set up...
Pyro...
Boost...
Tranny temp...
Oil temp...
Water temp...
Fuel pressure...
Oil pressure...
Exhaust back pressure...
Diff temp...
Volt reading...
Let me know what you think... got something coming I think...
Please excuse the pic, crappy cell phone. Ran over my camera...
CSIPSD is offline
post #2 of 10 (permalink) Old 07-13-2010, 05:34 AM Thread Starter
CSIPSD's Avatar
WOW... Crickets...
CSIPSD is offline
post #3 of 10 (permalink) Old 07-13-2010, 11:54 AM
is here and there.
Rcannon's Avatar
Images: 11
IMO..any temp guage.
Rcannon is offline
post #4 of 10 (permalink) Old 07-13-2010, 01:46 PM
4cstr's Avatar
Images: 35
One question...would these values vary depending on the motor. For example...does the max EGT differ on the 6.6L versus the 5.9L versus the 6.0L versus the 7.3L versus...
or fuel pressure
or boost
Would these "warning lights" be adjustable per the user...or pre-set from the factory?
~Dave~
4cstr is offline
post #5 of 10 (permalink) Old 07-13-2010, 04:33 PM
balz out's Avatar
i think every one of those except for boost. weather its a low/ high pressure alarm or high temp
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #6 of 10 (permalink) Old 07-13-2010, 10:40 PM Thread Starter
CSIPSD's Avatar
Looking more for a temp range that you guys think one should be triggered...
oil temp- 215*
Water temp- 215*
so on and so forth...
I'll respond to the others later, got to run.
CSIPSD is offline
post #7 of 10 (permalink) Old 07-14-2010, 11:50 PM
TDG Mafia - Booze Runner
Snowaholic's Avatar
oil temp- 215*
Water temp- 215*
Like you need any more lights, dingers, buzzers, alarms and so forth.
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #8 of 10 (permalink) Old 07-21-2010, 06:49 AM Thread Starter
CSIPSD's Avatar
You should get one for the dudge...
WARNING, YOUR PCM IS ABOUT TO GO ON THE FRITZ, PLEASE INSURE YOU ARE NEAR A DEALER...
CSIPSD is offline
post #9 of 10 (permalink) Old 07-23-2010, 05:39 AM
hayjayhorses's Avatar
on a 7.3 powerstoke
Pyro...pre turbo 1300* post 1000*
Boost... 25* (with stock turbo)
Tranny temp... auto 230*( w/ probe in the hot cooler line coming out of tranny) 200* ( w/ probe in the tranny pan) manual ZF5 250-260* (they run HOT) ZF6 220*
Oil temp... 250* I had a CAT 3406 that ran 230-245*oil temp
Water temp... 215* (w/ probe in the thermostat housing) the stock gauge jumps up @ 225*. 240* running Evens Coolant
Fuel pressure... less than 30psi
Oil pressure... Less then 10psi
Exhaust back pressure... 20 psi less than what the valve springs can handle.
Diff temp... 250*
Volt reading... <12.25 and >14.6
how about the
cylinder head temp?
Tire monitoring system?
Air filter vacuum?
Front diff (for the Dodge and GM with no lock out hubs) 160* in 2wd 250* in 4wd
Transfer case 250*
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #10 of 10 (permalink) Old 07-25-2010, 10:07 PM
this is just my opinion, and for my 97
Pyro...1350
Boost...none
Tranny temp...220
Oil temp...220
Water temp...220
Fuel pressure...not sure
Oil pressure...20
Exhaust back pressure...unknown
Diff temp...220
Volt reading...12.5 and lower or 15.5 and higher
2007 Dodge Ram 2500 lonestar 5.9 CRD, 6-Speed
full MBRP 5" turboback, S&B intake, FASS, ISSPRO gages, BD Diesel steering stabilizer, Tough country leveling kit, Air lift Rear leveling, Southbend clutch, XD Hoss 18" wheels, Nitto Trail grapplers, Satellite radio, LED tailights
1997 ford f-250 POWERSTROKIN auto ex cab LB, homemade intake, superchips programmer, trans, egt, boost gages, tripple a pillar pod (daily driver)
2005 dodge SRT-4 2.4turbo ED hard pipes, aem short ram, MPx 3" turboback, HKS SSQ BOV, AEM wideband, Motegi Mr7 18"rims custom painted (weekend racer) [email protected] 107
2001 suzuki GSX-R600 K&N, Two bros. exhaust, neons, polished frame, (sumertime DD, and track toy)
11.000 @ 127
2006 raptor 700R blue dirt toy
2006 raptor 700R white dirt toy
just visiting is offline
Low tire pressure warning light ERTERT222 General Ford Truck and Excursion 7 04-05-2010 04:32 AM
Fuel Pressure Warning Light? NCfarmboy 2003-2007 6.0 Tuner Forum 6 02-03-2009 06:53 PM
TPS Warning Light wolfeyes89 2008-2010 Body & Suspension 37 01-23-2009 04:44 AM
Emissions warning light? iknownothing 2003-2007 6.0L Power Stroke 12 01-18-2008 11:52 AM
HELP! ABS Warning Light TowRig General Ford Truck and Excursion 3 04-15-2007 07:37 PM
